Makeover time!! GS400TT upgrade/build has begun (pic happy)
#34
#37
This is AWESOME...flat out! Just FYI Mo from SRT (Swift Racing Technologies) got his GS400 running 12.7s (in 2001/2002?) in the 1/4 with his custom SRT TT setup. I'm sure you can replicate or do even better with the newer parts and technology of today! BTW I believe Mo was using street tires as well! Good Luck man and I know you can do it!
#39
So things have been moving along relatively smoothly. I recently sent out the pistons to get antifriction coating to the skirt and a thermal dispersal coating to the dome/face. Embee performance did a fantastic job and the turnaround time was much quicker than expected.
this is the piston prior to coating
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5725-1.jpg)
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5726-1.jpg)
I really love the look of clean pistons. When I got back the set after getting the coatings placed, I was bummed .....................
because now I wished that the head was transparrent so I could see these babies at work.
Here is the magic that was performed.
side skirt with antifriction coating
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5773.jpg)
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5760.jpg)
Top with thermal dispersal coating
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5764.jpg)
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5761.jpg)
The work is excellent. I went with the coatings due to the fact that I can make the tolerances on the "tight" side without worrying about scuffing. I also have heard nothing but good things about these types of coatings from engine builders.
#40
Now I had to make some type of formal introductions since the Pistons were gonna be mated for "life" with their partner "Rod" (Lextreme Lightning Rods)
so here are the eligible connectors
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5778.jpg)
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5776.jpg)
and the pistons
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5775.jpg)
And initial pairings, final choices will be made at a later date.
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5782.jpg)
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5786.jpg)
this thread will be updated again shortly as I understand that another main part is on the way.....
Stay tuned. I am sure some of you guys are gonna love this one.
and the pistons
#43
So as with any build, you can only really start when the final piece arrives.
As most of you who have followed the thread have noted, I already have my bottom end pretty much covered. (no pun intended) LOL But the one thing that I wanted to make sure is that everything is slippery-smooth. So I got bearings that were coated to ensure the rods and mains were rotating as smoothly as possible. I entrusted Calico to supply the ACL coated bearings and thrust washers.
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5788.jpg)
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5796.jpg)
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5797.jpg)
The valve train for the 1UZ is ok, but I wanted to make it more aggressive. So what could I do? With the assistance of Cowboy (Eric) at TTC performance, a set of cams were hardwelded by a well renowned cam specialists to new specs that benefit my turbo setup. I did need a set of core cams and this was purchased from Adesai8. Here is the final result of hardwelding and cleaning of the cams.
[IMG]
http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5810.jpg[/IMG]
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5813.jpg)
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5816.jpg)
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5814.jpg)
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5823.jpg)
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5826.jpg)
The block is currently at the machine shop and should be set to go soon. I'll post again when it gets done.
![](http://i102.photobucket.com/albums/m86/hi98gs/Rebuild/DSCF5806.jpg)
