Turbo vs. Swap
Turbo vs. Swap
Okay guys,
I have a 2003 gs300.
I would like to get it up to about 400-450 hp.
I was thinking about going with the Swift Racing Turbo kit and bulding up my motor from there. I hear that once you hit 350hp that you need to have your trans rebuilt or something.
Then I was thinking about doing the 2JZ-GTE swap, but thats like 280hp.
So do you guys have any suggestions on what I can do?
A N/A motor can run a max of 8lbs safely on pump gas. If you do a headgasket you can run 10-12 lbs safely on pump gas. Doing a basic setup on a NA motor is going to be cheaper up to a point. Once you decide you want to make big power (and trust me, you will want to) you are going to be spending more to get over the limitations of the NA motor.
Your call, people have made good power either way. Personally I went with a swap and a basic single setup and have been making roughly 585hp at the crank (465whp) for two years now with no issues.
2JZ-GE Single Turbo Kit: $1649, shipped FedEx!
NON-VVTi read the description to order for your motor
T61 turbo - use 4Runner distributor cap and rotor to avoid interference issues
12x24x3" polished aluminum front mount intercooler (4" upgrade available)
2JZ-GE polished stainless steel manifold, fully braced
40mm wastegate - compare to HKS
polished stainless steel dump tube
Choice of blow off valves, compare to Turbo XS -OR- Blitz
** or upgrade to 50mm V-Band mount BOV - RED, BLUE or clear anodize $40 extra - compare to Ti-Al
** or upgrade to sequential style $30 extra - compare to HKS)
3" v-band clamp kit
3" v-Band polished stainless steel down pipe with 02 sensor bungs
teflon and braided stainless oil supply line, high temp drain lines & flanges
gaskets
turbo oil return plate (to oil pan)
This is the kit most go with but you'll still need other things like fuel mods and intercooler piping. Check out the site it is very informative.
One thing that blows me off about these kits is the fact that the cold side of the intake going into the throttle body goes right over the turbine, which heats the air back up before it goes into the motor. It's not a very efficient setup.
Why not just get turbos, hard pipes, and manifolds off a 2jzgte. You could probably pick the entire system up for less than $600 used plus all the things for fuel management. Check out supraforums.com there's always some for sale.
Secondly, it's not like the air is just sitting stagnant in the piping, the air is moving very quickly. The amount of heat that would actually be picked up from that one little section crossing over the turbo would be practically nothing.
