F-Sport Sway Bar..
I use "..." ....... a lot
All in all, I'm very pleased with them. Sure, there's still some understeer, but it takes a lot more pushing to get to that point.
BTW, installation is pretty simple.
Installation is simple? The F-Sport installation was simple.. but from what I have hear..the sway bar will be far more difficult to install.... since I have to remove the tires.. how long did it takes to install? Installing the F-Sport intake took about 45 minutes.. (would take about 1/2 that time now). Can I do it without a car lift?
2) I did mine by putting the car on ramps (fronted it on for the fronts, backed it on for the rears)
3) It probably took about 90-120 minutes, but that was me having help from an experienced individual. I got pretty frustrated at it because it was somewhat cramped in there.
I'd say that it's something that's somewhat simple if you've got experience doing those types of things, and you have a garage with a good set of tools.
BTW, you do NOT have to remove the main engine undercover completely. You can loosen it enough to slip the sway bar through.
