GS300 Intake + Exhaust question
Old 08-19-08 | 12:20 PM
handzilla's Avatar
handzilla
Default GS300 Intake + Exhaust question
If I installed and intake and exhaust on my GS300 would this increase or decrease my MPG?
Old 08-19-08 | 08:40 PM
Downfall75's Avatar
Downfall75
It should increase. Unless you mash the pedal to listen to the sound.. which you probably will...
Old 08-19-08 | 09:55 PM
macd7919's Avatar
macd7919
If you were to drive the same as you did before the intake and exhaust install it would increase your mileage, you are adding more air which will make the car run a little leaner which will give more power at any given throttle input resulting in less fuel needed for the same output.
Old 08-20-08 | 12:36 AM
tommyjaix's Avatar
tommyjaix
I'm running an SRT intake w/ ecu and Tanabe Medallion Touring Exhausts and I can say that the mpg went up to about 2mpg after the intake install and its about the same if not 1 extra mpg after the installation of the exhaust. Should probly total to about 3-4mpg if I dont push the pedal so hard everytime to listen to the sexy growl of the setup =p
Old 08-30-08 | 10:32 PM
fordsvtmfl's Avatar
fordsvtmfl
I put on a HKS Hi-power axle back, Weapon R intake with a K&N Filter, and changed the plugs to Bosch Platinum Ir Fusion..and i went from 17-20 mpg...
Old 09-01-08 | 10:11 PM
4ntvings's Avatar
4ntvings
i dont think it makes a whole lot of difference. 1-2 mpg variance is minimal and not noticeable to me. its all noise to me; i have a drop in + MT on.
jamminlol
09-08-10 08:48 PM
Bullskim
Performance
05-14-08 06:14 PM
KGDeAng
05-05-07 02:17 PM
LaoKidd2k
IS - 1st Gen (2001-2005)
12-14-06 07:28 AM
nine9898
Performance
14
10-30-06 07:31 AM
