Trany Cooler
Trany Cooler
So I have read and read and searched and searched, but I do not see any DIY step by step instructions anywhere for installing the trany cooler. Everything I have read says that it should be a simple install but I am hoping to be 100% on top of it before the product arrives. Can anyone direct me to an install write up?
Also, if PPower wants to talk about his custom set up with brackets and custom bent metal hosing I would appreciate some info on that as well!!
Thanks.
Thanks.
it is simple you just have to mount it and connect two houses. On my car there are two hoses running from the trans to the radiator. Take one hose from the radiator and connect it to the cooler and then the return from the cooler back to the radiator. Thats what I plan on doing anyways since it will allow me to use the stock method as well as the new cooler.
Guest
Posts: n/a
