Top 10 1/4 Mile Times GS300/GS400/GS430
#154
This would give more members recognition especially the V8 members as the Turbo 6 members (doing a great job btw) have it relatively easy compared to the scarce options for going fast on the V8.
As far as what the V8 is capable of:
My 1999 LS400 (1998-2000 MY) has the same engine transmission and differential as the GS400. The LS weighs a couple hundred pounds more. My best stock times are as good as I have ever seen for a stock GS400. I did the 14.2 on a 2.19 second 60ft (on stock 225/60-16 radials) with the stock non-LSD 3.27 differential. With LSD and drag radials I am completely confident that I would have gone 2.0 or maybe even 1.9 on that 60 foot time which would have had my LS going high 13s.
With less weight the GS4xx SHOULD be slightly quicker under the same conditions. With headers, 2800rpm torque converter, LSD, drag radials and a tune I am confident that a properly driven GS4xx COULD go 13.5 at 100-102mph.
If someone decided to get into the engine a bit as most 2JZ owners eventually do... Properly ported heads and intake manifold, mild cams, bumped compression, could get 300+rwhp NA which could get very low 13s at 105+mph.
Properly boosted with a JeffTsai built A650 transmission 550rwhp may be attainable on the V8 platform. Given the stronger torque curve in the lower RPMs such a configuration should give many higher powered 2JZ cars a TOUGH run...
#155
I think there should be TWO columns: GS300 and another for GS4xx
#156
You took the words right out of my mouth. We should have one for the 4xx guys NA or FI, I agree! According to your calculations if I was to bring down my 60ft from 2.2 to 2.0 or even 1.9 how many .second would that shave of my 1/4 mile time? I ran a 14.1@99mph with a 2.2 60ft no lsd nor tq converter, no sicks either, on stretched tires. But I'm looking to get those upgrades if it would help me break into the mid or even low 13's. Thanks
Hopefully Adam will add the 4xx column since very few of the V8 cars are FI.
As far as time reduction in your 60 foot time calculating to a change in the 1/4 mile...
All things being equal...
The minimum ET (elapsed time) reduction would be a 1 to 1 ratio... IOW... drop 0.20 in the 60ft (2.0 vs 2.2) and your ET drops at the MINIMUM from 14.1 to a 13.9
Now, due to the nature of drag racing the drop is often MORE than just the raw change and can be 1.5x or even 2x the 60ft change... IOW, a 0.2 drop in 60ft could be worth 0.3 or even 0.4 in the final ET. Notice I said "could" and "all things being equal" as that is not often the case.
Still, with a bit more stick to your tires, either DR or LSD or both and you should easily see 13s in the same ambient conditions as you ran your 14.1.
The conditions were outstanding for my 14.2 run with temps in the 50s, a high barometer and low humidity.
#157
Nice to see a GS finally post a better time than my LS
#158
Much respect to all the fast 300's out there, but don't leave us 4xx guys out also. Hope this list can motivate some 4xx guys to go fast also and post up their times. I made up this list due to the information i see in this thread.
Hope Adam can update this for us
1. JMECBR900_12.6 @ 112 mph GS400
2. KlynchGS4_13.2 @ 104 mph GS400
3. 1MOGS4_13.52 @ 104.90 GS400 W/ Nitrous
4. BIG L_14.01 @ 103 GS400 N/A
5. denut-L _14.1 @ 99 mph GS430 N/A
6. dcz _14.26 @ 99 GS400 N/A
7. Adam2562_ 14.5 @ 97mph GS400 N/A
8. maintrain _14.635 @ 95.73 mph GS400 N/A
9. DumpedGS_ 15.18 @ 96mph GS400 N/A
10. OKC-GS400 _15.2 @ 97 MPH GS400 N/A
#160
i hit a 14.41 at 97.4 to update that..
#161
Northern California Regional Officer
Reppin GSxxx
I just got drag radials for my GS, so I'll be doing some test & tune at Irwindale Raceway during THE PURSUIT3 meet coming up this Oct.
Event Here: https://www.clublexus.com/forums/cl-...0-16-11-a.html
It's a 1/8 mile track, so I'll be focusing on my 60ft.
I'll try to run on a 1/4 mile track some time in the future.
My car Dyno'd at about 400 rwHP.
I've got a Vortec Supercharger @ 8 lbs, S &S Headers, 2 1/4 catback with x -pipe, Patriot Varaflow mufflers, Hi Stall TC, Valve Body mod, Carbonetics LSD, 285/40-18 Nitto Drag Radials
What does everybody think the car is capable of in the quarter ?
20" rims up front & 18x9 rims on Drag Radials out back.
BTW perhaps we should start a new thread?
#163
#164
Mo from SRT back in 2007
12.030 1998 GS400 Custom Supercharger
((No, SRT doesn't sell this supercharger (or any for that matter) for the 400/430's.)
http://www.youtube.com/watch?v=8GsduKXNM7M
#165
Kind of OT but, any of you guys who are running/going to run slicks, what wheels are you going to use? I'm going to throw slicks on my stock 16's and I have no idea what size to buy.
