New IS300Turbo 6Speed comming out of Toyomoto
well...DT1313 is the proud owner of a sweet *** is300 that he is getting back from Toyomoto this weekend....but here is some info about it...
2002 is300...5spd converted to 6spd
stage 2 toyomoto turbo
Getrag 6 speed from a supra
RPS clutch
custom drive shaft..
Stock internals
toyomoto head gasket to lower compression
the car dynoed at 490 rwhp on pump gas and 19psi...then threw in some race gas and dynoed 570 rwhp on 25psi...
Also unique to this car.....it has the sc300 throttle body to eliminate the drive by wire...and NO SPEED LIMITER.....
on the dyno while tuning...the car on a test run reached 176mph......
the car drives beautiful ....im sure dan will be posting about it....if you got more questions feel free to ask.....ill answer as best as i can.....congrats DT1313...the car is AMAZING.....Jeff
P.S. this same kit can be done on the gs300...any year..incase someone is looking for some Gs400/430 whipping power
RPS clutch
Stock internals
RPS clutch
Stock internals
RPS clutch
Stock internals
Do we not need the custom drive shaft if we're not gonna use the 6-speed getrag? If we only want the turbo and still keep AT, all we need is the turbo kit right? (and the head gasket)
so is this a bolt-on kit?
it needs to be installed at toyomoto and they include a haltech in the kit....stage one is 8500 installed and will get ya around 300rwhp.....drive shaft was needed for the 6spd......305-599-3050 and yes it can be done on the 98-2002 gs300
Move to IS300 or Lobby.
SC300TURBO
SC- 1st Gen (1992-2000)
02-16-02 12:55 AM
