Personally, I think any hp claims from just swapping out your oil is negligible. Even if it were true, do you think you're gonna feel 3hp?
I think that if you can manage to get a good synth oil on the cheap (like Mobil 1), you'll do just as good.
You'll have a hard time feeling the difference even with the 10 hp gain let alone 3 hp. If you want to use Synthetic, you are more than ok with Mobil 1.
I just use Mobile 1. I guess you can try them and get them dynoed to see :-P but that would be if you've got money to spend and time. But still it's almost a moot point with 3 hp.
the only oil i kno that gives u increase on performance is a oil called enu something like that im not sure it from japan n expensive it like 8 or 7 buck per bottle
You're talking about Eneos..awesome stuff, I put that through my RSX-S all the time, that and Amsoil.
I use Amsoil synthetic but I mean royal purple is a great alternative too, a tad cheaper than Amsoil as well..
+1 i use amsoil euro blend for my a4 my oil runs 15 degrease cooler than mobil 1 ( my a4 has a oil temp gauge) my mpg improoved and the engines is quieter too. i also do a seafoam treatment every 3k through the vac lines in the tank and pour half a botle in to the oil pan 100 miles before oil changes
Slick50 does all that too, but I wouldn't run it in my street engine.
