what is the safest way to change the wheel?
hi, today i was trying to change my wheel by my own, and end up with breaking 2 wheels studs....and it cost alot to fix it. sigh...so what is the safest way to change the wheel? i don't wanna break it again...
and also i have the ING body lip all around, and the OEM jack is not fit..(the jack will push the body before push up the car) so you guys with those body lip, which jack are you guys using?..any suggest?
I don't know how you managed to break two wheel studs in one shot. I've taken rims on and off cars hundreds of times and never broken a wheel stud.
For your jacking question: Get a low profile floor jack and then, if you need, use a hockey puck in the middle of the jack pad to push up on jacking point. It sounds like you're new to this so remember, always chock a wheel that will be staying on the ground.
