Lexus IS350 06-07 Prostreet S/C Kit
Old 12-08-08, 08:07 PM
  #301
iSuxeL
iSuxeL's Avatar
Many?? There's only like 7 LOL
Old 12-09-08, 02:56 PM
  #302
Kurtz
Kurtz's Avatar
Originally Posted by yayitscola
Nice, video. Maybe one day our ecu will be cracked and we can be like all the other turbo cars, 10psi+!
Won't happen.
And the ECU isn't the problem. TOMs can flash the ECU in japan no problem, they still max out at 5.8 lbs of boost.
12:1 compression is the problem, and there's no sane affordable way to fix that.
Old 12-11-08, 07:01 AM
  #303
Robs IS250
Robs IS250's Avatar
friend of mine bored his out to a 4.0... hes currently out of the country so ill ask him exactly what he did.. i know for sure rod, pistons etc.. all custom
Old 12-17-08, 10:25 PM
  #304
pli
pli's Avatar
wonder if with this kit, can it beat the e46 m3s
Old 12-17-08, 10:30 PM
  #305
Sytfu_IS
Sytfu_IS's Avatar
if the e46 is stock yes, it's not that much faster then our is350's
Old 12-18-08, 08:39 AM
  #306
javyLSU
2IS OG
javyLSU's Avatar
You don't need a supercharger to beat a stock e46 m3 in an IS350. Straight line acceleration in the IS350 is slightly better (as long as you're not running 20's or some other nonsense). I've beaten every single (stock) E46 I've ever raced against.
Javier
Old 12-18-08, 10:00 AM
  #307
iSuxeL
iSuxeL's Avatar
I second that!
Old 12-19-08, 06:38 PM
  #308
datplayaz
datplayaz's Avatar
Originally Posted by iSuxeL
You should look into a rear mount turbo. I'm contemplating this idea for the moment...
there's a company here in Utah call STS Turbo that does the rear mount turbo, i've seen this kit in person on a 350Z and a GTO, it's pretty impressive... i've thought about going to them to turbo the IS350, but I don't know what to do with the Engine management issue yet.
Old 12-21-08, 03:15 AM
  #309
GILLEXUS
GILLEXUS's Avatar
Originally Posted by passnu2
are you doing this on your GS430, if so what year I would like to see and hear more about your set up if so
I'll PM, you I already have one for it I have an 01
Old 12-21-08, 08:56 AM
  #310
iSuxeL
iSuxeL's Avatar
That's the company I was going to go with. If you keep boost regulated at 5.5-6lbs max you shouldn't need management.
Old 12-21-08, 07:51 PM
  #311
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,990 Likes on 2,414 Posts
Really? Bored a 2GR to 4.0 liters? Or bored a 4GR to 4.0 liters? Either way, you're saying you've bored through the entire liner, into the block and had to replace the entire cylinder structure in the block. Who did this ground breaking work?
jasonr
05-29-15 03:36 PM
chi123
Chicago Lexus Club
13
07-13-12 10:25 AM
kit cat
06-28-11 01:21 AM
montgb
Performance
72
05-22-09 07:16 PM
cdiddy
Performance
08-28-06 12:56 PM
Quick Reply: Lexus IS350 06-07 Prostreet S/C Kit
