...HOLY crap! Loose spark plugs!
Old 09-20-10 | 03:18 PM
TLcoats's Avatar
TLcoats
Originally Posted by Rock-a-Lex
^ It wouldn't hurt to re-check them again soon. If they are still snug then they most likely will be fine from then on out. Usually, just like lugs on your wheels if they get a little loose it would be within the first week of driving. I always re-check my lugs a couple days after I remove/re-install my wheels. If they are ok then I never re-check them...same goes for the spark plugs; at least in my situation. Oh, and I am sure that they were fully tightened the first time around. Not sure why or how they came a little loose...only 2 out of the 8 spark plugs got loose at that time.
Thanks for the help. I need to buy a torque wrench anyways so i'll double check everything just in case. And btw, Do you have any recent pics of your car? I've always been a fan of your car and havent seen any updates lately!
Old 09-21-10 | 06:18 AM
Rock-a-Lex's Avatar
Rock-a-Lex
^ Anytime. I'll try to post some up for you in a couple of days. She needs a good cleaning anyway so once clean I will do a quick photoshoot and post up on the forums. Thanks for the compliments.
Old 02-20-23 | 08:50 AM
jsugalski's Avatar
jsugalski
1st Gear
This is an ancient thread and half the people in it might be dead, (including the vehicles) but it helped me diagnose a pesky lean code I couldn’t figure out on my Nissan Pathfinder and so far the one loose spark plug seems to be the problem for bad mpg and the lean code! So thank you!
MOAWINGS (02-23-23)
Old 02-26-23 | 10:46 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Glad you found the issue! I still lurk around here once in a while.
lexusdave
Performance & Maintenance
26
06-20-14 05:10 PM
mrblister
GX - 1st Gen (2003-2009)
08-19-13 10:56 AM
UNDR8D
21
09-26-12 05:57 PM
makulaf
15
05-25-08 11:43 AM
