Looking for digital pictures of installed SRT Intake on GS300
I'm having some issues with my intake that are turning the check engine light on.
The car operates fine, however I did notice one issue. When I pump gas I cannot insert the pump all the way into the tank. If I do, the gas will turn off after about 2 gallons since the pump thinks the tank is full. Clearly this is a sensor issue.
I'm thinking this may be related to the Vacuum Switching Valve (Part#90910-12220) and I'm guessing this should be removed when the intake is installed.
The instructions from SRT are beyond terrible and weren't clear as what to do with this. I even called SRT and although he didn't seem quite sure what to do, he said it should remain attached.
I'm hoping someone could offer some insight and possibly attach some high resolution pictures of an install so I can compare it to mine. I needed to get my inspection done yesterday and I can't until this is resolved.
Thanks
Thanks
Updating with error codes
P0446 - Electrical circuit for the vent control in the evap. emission control system
P0451 - Voltage signal from the pressure sensor in the evap system is out of range
P0441 - Purge flow in the evap system is incorrect
Can anyone even answer if the VSV is supposed to remain hooked up when the intake is installed?
Please help!!
Please help!!
You might want to check your vaccum hoses and your evap canister and sensor. or try doing a 15minute ecu reset.
Thanks for the reply.
I've done the reset, and it comes back.
The pump issue happens at EVERY gas station I go to. If there is no sensor that is related to this, then that would mean the gas is somehow staying around the neck of the pump?
The issue never happened in 5 years until I put the SRT on the car, and the hoses are all brand new that I purchased locally.
Any info on the VSV?
sorry i havent gotten time to take pictures yet. but i stumble onto this post. hope it helps.
https://www.clublexus.com/forums/sho...d.php?t=384123
like i said there shouldnt be a sensor. but check with the above thread and i will come back with pictures.
2002 GS300
That thread is the same problems I am having, and there was a mention of somene with an intake having the problems.
Back to my install
We soldered the ECU and 3 of us checked it before taping it back up and closing it. I can say I am extremely confident the problem doesn't lie there.
For the hosing though, that could be the issue.
I purchased this off "NBart" and he said he used the Lexus stock hosing, which I tried but it was about 2 inches too short.
I took the hosing to AutoZone and they gave me a few feet of the same stuff.
I ran the hosing from the tip of the filter.....
**It wasn't as tight as the instructions said it would be since it didn't come from SRT and they were unresponsive to me when I requested tubing from them**
....to the VSV and then hosing from the other end of the VSV back to the car.
Then there was also the issue of the VSV just hanging there since there was no spot on the SRT intake to bolt it down to.
Possible problems
The hose at the tip of the filter isn't snug enough.
Or a long shot (although I'm not sure if the car would start)
The hosing is connected to the opposite ends of the VSV.
Pictures would help answer this definitively.
Back to my install
Possible problems
generally the hose from the top of the filter is not the problem i sometimes disconnect it and its not a problem at all. you might want to check your other hoses after the maf sensor.
this is what i dont understand.
check wiring, the gs has 2 differnet maf sensor. one from 98-00 and 01 and up. your 01 and up should use the diagram below. borrowed this from myis fourm.
Unless I am missing a part or something, this VSV for EVAP has nowhere to bolt into. I zip tied it to the intake tubing so it cannot move.
I re-checked the ECU wiring and that still looks correct to me.
Side question: Do these errors have a negative effect on the car or is it just an environmental issue?
its somewhat to the gas ecomony but nothing real bad. but should be fixed right away.
well try removing the srt intake and the ecu module and clear the codes and see what happen. from this point its vacumm hose, the ecu, the vsv module.
I have code P0441 and P0446 on 1998 GS300. I looked under the hood, but couldn't locate the VSV nor the Vacuum Canister. Can anyone provide pictures showing the actual location of the EVAP EMISSION SYSTEM Components ?
I have code P0441 and P0446 on 1998 GS300. I looked under the hood, but couldn't locate the VSV nor the Vacuum Canistor. Can anyone provide pictures showing the actual location of the EVAP EMISSION SYSTEM Components ?
