Their May Be Hope! PSI........
So I was reading the new Modified Mag this week and noticed they featured a Toyota Camry with a GT28RS turbo. This is the 2GR-FE 3.5 liter V6 motor BTW. Cobb tuning is who fabricated the kit and has access to download there access port software for tuning. I took this kinda lightly and decided to call Cobb tuning. After three days I finally reached someone. Couldn't get much besides they are currently working to get the rights to the Toyota ECU's. Was told to look for Toyota and Scion Access ports to be released first then Lexus to follow if everything works out the way they plan.
As for the Camry it went from a base HP of 268 to 335 HP. Not bad.
Also I noticed that AEM is finally making a Drive-By-Wire ECU now. Looks like the Subaru's will be the frist to get these.
May be hope guys??????
May be hope guys??????![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
if they can crack the ECU
(dont see how they can or will since everyone has been trying) then you wont need to! What you have with the boos turned up and a new BOV!!! Turbo>SuperCharger IMO but since you have the set up keep it and save the $. The S/C you have is good![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I would love to see this go down and take the GS to the next level.
Nice find
Nice find
Not to dampen enthusiasm, but it remains my belief that the ECU won't help much.
TOMs can change the ECU in japan and their supercharger runs a whopping 0.8 lbs more boost than the LMS one does on the stock ECU. (and takes 100 octane fuel to do that much)
It's the 12:1 compression that is the enemy to boost here, not the lack of ECU programming.
The Camry engine by the way has a 10.8:1 CR, so it's unsurprising it can handle more boost.
They added 67 hp at the engine, so probably around 55 at the wheels. That's a whopping 15 more than the LMS supercharger adds... and with the benefit of no parasitic loss from turbo vs. blower.
So they're like running, I dunno, maybe 6 lbs, and all of that extra lb thanks to the lower CR.
I suppose if they could have the lower CR -and- ECU flashing they could let it use 100 octane fuel and maybe manage 7 lbs, but that still doesn't help us much.
I'd love to be wrong, but I remain pretty sure a 12:1 CR isn't going to get much over 5-6 lbs of boost on just pump gas no matter what you do with the ECU
I wouldn't hold your breath for any ecu tuning for the 2IS, High comppression and direct injection, which seems to only be available in the Lexus products, have just about maxed the the 2gr-fse in NA form, and I doubt Toyota/Lexus are going to let go the coding to modify the ECU.
There are several versions of the 2GR FSE in the Toyota stable, the aussies are getting a supercharged version, but it runs much lower compression and is not direct injected, hence the reason why Cobb is able to pull off a turbo'd 2GR and can reflash the ECU. The access port is great, used it on my subie![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
If you guys wanted a real tuner car, well, we bought the wrong car.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
^ Not so much worried about the turbo kit but more the ECU tune. I doubt I would boost this motor. But add some timing, tweak the fuel duty's and adjust the rev's up another 500-750 rpms. Thats all I want.
