Whats wrong with $600 ebay turbo kits?
Ok I know there are PLENTY of folx who just dont like ebay, I'm not looking for ebay slammers....
If someone isnt looking for huge gains and what not, whats wrong with just getting the inexpensive kits off of ebay?
Personally I'm interested in a turbo just to fill in that void that screams "GIVE ME TURBO" on the GS3. Dont really care about gains cause I'm sure it'll have some either way... so yea, what are the downfalls about that?
First of all it's going to cost more than $600. More like around $1200-1500 range for a "ebay kit". Second of all, it's not really a turbo kit either. It's just a couple of generic parts slapped together in a package, and not everything is of the highest quality. It will work fine, but not under extreme duty or for a very long time. You still have to do a bunch of custom fab work for the intercooler piping, and exhaust piping. Then there's mounting and lining up all the parts. After that, you will need to setup some kind of engine management to tune the car for higher fuel consumption. To top it all off, it comes with no instructions on how to do any of it.
So to sum it up, if you're good at DIY and know your way around turbos and such....then the ebay kit is a viable option. If you're looking for a simple to install and no issues setup then the ebay kit is not for you.
EDIT: In addition to the above. Most shops won't even touch the ebay kits because they're so incomplete. OR they will charge you out the *** for the extra labor if you really want them to custom fabricate everything on that kit to work for your car. So again, unless you plan on doing all the labor yourself or have a very good friend that is willing to help you out for cheap/free then try to stay away from the ebay kits. It might end up costing as much as a brand name kit if you take it to a shop to get installed
cool, some great points. and yea I would do the work my self and KNOW my way around engines, just not the GS. I have a fully built drag car in the garage
and yea, obviously a tune would need to be had...
now you said parts would have to be lined up? which would those be? and you also mention about lots of fabbing? I thought that those kits were specific for the 2JZ engine? and were complete?
wait, I just read them again. they do say "universal" and no instructions.. so I see what you're saying. but other than the routing of the intercooler piping, wouldnt the DP, turbo manifold and turbo all be bolt on?
again, i'm ignorant to our engines
The intercooler piping will have to be fabbed up. The downpipe will bolt up to that turbo, but you will have to make a custom B-pipe to attach from the downpipe to the Y-pipe. The stock B-pipe is a dual 2" into one 2.75" pipe, and the downpipe is just a single 3". Other than that everything should bolt up. Run the oil lines, drill and tap the flange for the oil return on the upper oil pan, bolt everything together and you should be good to go. You will also need a MAF flange or pipe with one welded on. Other than that everything should be relatively straightfoward if you know your way around turbos and engines. Just hook up the engine management, and upgrade fuel pump/injectors if you plan to go a lot more than stock power.
Oh yeah, if it were me I would keep the boost on those parts around 10-15psi range. I don't trust that cheap wastegate keeping my engine safe at 30psi lol.
yeah i was going to say, the actual turbos themselves from ebay are generally useless and make well short of the power they claim to make. also, the wastegates are normally not that great at regulating boost and also the few ive heard of tend to die quite quickly as in oil seals go or the bearing go and they chew themself up. i havent heard any good things really about them..!
i guess its hard from my angle here in Australia but we get Garrett turbos quite cheaply relatively speaking so most people over here just go a Garrett turbo with universal lines to suit and then fab up the bits and peices as necessary which is pretty much what you would do with the ebay 'kit' anyway. I mean when you are going to the effort of fabbing things up to suit the turbo you might as well try and get one that will last some time!
