OEM Motor getting Supra TT GTE Head?
Do people regularly go with the Supra 2JZ-GTE head, harness, and stock twin turbos?
I dont want to hear about my NA-T options, I know this is a possibility.
Thank you.
Thank you.
No, people usually either NA-T. Or swap the bottom end to GTE to hold more power(still NA-T). Or the third option is to swap the entire GTE engine. No point to bolt a GTE head onto the GE block with weaker rods and pistons. It will look cool, but overall a waste of money unless you upgrade the bottom end as well.
you can do a gte head on an NA bottom end with a thicker head gasket. with all that you can run all the gte goodies.
i dont think that would be too cost efficient since it is usually easier to find a whole motor rather then piece stuff together. a good condition gte head, turbos, harness, and other accessories will almost make you want to buy a complete gte motor.
