SS Headers input, question
#31
So, although a few hp can make a difference, ordering the wrong parts will make a bigger difference in wasting money
Besides, there is tons of information on these headers already. If you are interested, search S&S headers.
#33
the fonz has spoken
masboy, look into mazzuri supers for the 300. theyre the best for the 300 that i've heard so far.
dxb_8788...you're right, a lot of parts dont add the horsepower they say they will. But in this particular case, where you're discussing it with guys like fonzy (look at his sig pic) and speedaddic (look at the first line of his sig) i'd be inclined to listen. And what you're specifically referring to, is probably the fact that youre losing power through the drivetrain, which is inevitable. That's why its important to read the fine print and see whether the company is claiming those gains at the crank or bhp/whp
#35
I'd be down for an SS but I sure would hate to have them removed for smog!!!!
searched on found this ~$60 cheaper
I wonder wht's the difference? coating?
Damn, I shoulda done this instead of the overpriced SRT intake thingy!!!!!!!!!!!!!!! Is/was there a group buy?
#36
The headers come out from the bottom, but you will still need access from the top to loosen some of the bolts on the manifold.
#40
S&S headers are ok in the sense that they're so available. I'm sure there's a shelf somewhere with pallet loads of them. The problem I and other have with them is the fact that the construction is rather cheap. The piping is a mild steel with a very thin wall, and every set I've laid hands on has been prone to cracking. The fix for us has been to get the sets in, and then immediately reweld them with stronger materials so as to reinforce them. On a side note, and I don't want to pass this along as gospel, but the headers have a certain heir of being made in China for $30 a set. Holding them up the other clearly Chinese made manifolds, the similarities are apparent. It's a shame that it's the only real option now; a quality SS set with thick wall tubing would run quite a bit more than what S&S are fetching.
Eric
Eric
#41
Eric, your post is dissapointing. I am unsure as to your motivation other than some kind of competition with me... and that is unnecessary. I believe both of us have the same goal and that is to improve the performance of these poorly supported engines.
So, let me address your points which I consider at the very least misleading. I do this after you and I have already had this discussion online and I would hope that you would be more careful before making spurious statements. I am CERTAIN that you would hope for the same courtesy.
Well, NO, there are NOT pallets available. S&S is a small shop that builds on site to supply demand. The headers are "OK" because they WORK and make power AND torque accross the entire RPM range and improve the feel of the car both full throttle and in the important area of throttle response.
I am fairly sure you and I discussed this online specifically. The original 30 sets used 16 gauge tubing. Here is the first post on the thread I started specifically on this issue back in September.
https://www.clublexus.com/forums/per...nt-design.html
Should NOT be necessary. That said, if there are any problems that ANYBODY knows of with the CURRENT S&S construction please both post on CL and contact Loren at S&S. Also, please contact me as I am interested. So far I am unaware of any problem with the current parts.
Do your homework Sir... this kind of statement is slanderous. S&S are built in craftsmen Arizona USA not by slaves in China. Otherwise you could buy them on ebay for $150 and help kill American jobs while supporting Chinese slavery and environmental disrespect.
While not as thick as steampipe, 14 gauge is not thin. You are correct a quality set of stainless headers would cost much more than $600 if made in the USA.
I am actually surprised that your group has not come up with your own headers for the market... why not?
I just spoke with S&S Headers owner/designer Mr. Loren Barnes.
There has been NO reported failures/cracking of the current Lexus V8 headers.
The first run of headers, aproximately 30 sets, tended to have tubing cracks develop after several thousand miles of use. This resulted in S&S changing both the steel tubing thickness and welding pattern.
Original tubing thickness was 16 gauge = 0.065 inch tubing wall thickness
Upgrade/current design is 14 gauge = 0.083 inch tubing wall thickness
This is an increase in tubing thickness of 28%
#42
How come no other company makes headers for these cars?? It seems like there is a pretty high demand for them, so someone should grab a set of s&s and use them for mockup or build some from scratch out of better and thicker material. If I had acces to a welder and some pipe benders I would be all over this, but I dont. Im going to contact a few local shops to see what they say.
#43
I give S&S a lot of credit for taking care of the issues they were having with the headers and making things right for their customers, not many businesses do this
#44
JBrady, we don't produce any headers for the GS. There's no one that's willing to pay what they're worth. When we produce manifolds, it's out of .125 thick stainless and that gets pricey. Couple that with the low production numbers and there you have it.
I'm only disagreeding with you as I'm not cheering these mani's on. The only plus to the is the fact that they're available. And also fwiw, we measured tubing walls as thin as .048. That's way thin for mild steel. I won't go so far as to say that they're junk for that fact that they do fit, but the ones that I've held in my hands have had to be rewelded in order to strengthen the weak points. I know you say they're not made in China and that's cool. They just look it, that's all.
Laters,
Eric
Laters,
Eric
#45
It is not that I "say" they are not made in China it is a fact.
You say that you have measured tubing thickness as small as .048"
You say that all the units you have had needed rewelding/strengthening.
Didn't we discuss this on another thread. Didn't you say you did not know what batch you had or were refering to?
The originals were designed to use .065" tubing which is pretty standard stuff on street headers. Is it possible someone accidently pulled some 18 gauge (.049") for the set you mentioned? Yes, possible. Was the point you measured the outside bend? If so ALL tubing gets thinner as it is stretched by the mandrel. Did you actually witness the measuring or is this someone else telling you?
I would argue the best thing about the S&S headers is that the WORK. I doubt anyone will build a header that performs significantly better for the appllication (NA, near stock, stock replacement, uses cats as factory, over all performance including throttle response, low range power, high end power and efficiency/economy).
Do you have any pictures of your headers made out of .125" stainless?
I see you and or your customer are running the S&S headers on one of your high end efforts.
![](http://i15.photobucket.com/albums/a355/c0wboy/Eds%20motor/Picture004-7.jpg)
