SS Headers input, question
I searched a bunch of threads and sounds like theres a good bit of power to be gained. Is it really 20whp though? Guys that have added these ss headers, could you tell an improvment in power and sound or more less sound? Will they directly bolt on to my stock exhaust on my 02 430? Thanks, just looking for more input. Also, Im running the srt intake/ecu, welded in magnaflow mufflers and straight piped 2 center resonators. When I add the ss headers should I get the apexi neo and dump the srt ecu, is there untapped power I could find with this setup?
S&S headers will bolt right in and can gain 15-20hp eassy. I bet you can get more power if you ditch the SRT system and even more if you get A/F controller. Someone a while ago said they felt better response with Injen intake over SRT after installing headers. Adding headers will not change exhaust sound much, it just makes it sound a little deeper.
Why would you comment about them when you obviously dont know??
They do exactly what fonzy said. If you do a little research I believe there was a guy who dynoed 20 wheel so it is very possible to get that much power. I think it was on a 430 too.
A question I have about them is can you bolt your stock cats up to them? I want to get these but living in CA they are illegal. Im wondering how easy it would be to pull one over on the smog shop if I tried to make them look as stock as possible.
Thats awesome Im definantly gonna pick me up a set at some point than.
I have these on an sc430 (same engine) and you immediately notice the power right through the range.
The new ones are much better quality and had mine for about a year now with no problems.
It was pearlpower that dyno'd the headers in the SC430 forum.
Just remember anytime you post inaccurate staments, you are loosing credability, if that means anything to you, plus people think you are full ish.
My friend is crying right now. He just finished swapping an LS6 into his older camaro and needs it to be certified. In the meantime, he's rolling around in a Toyota Corolla ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Its hard enough to see the OEM manifolds already. I've always thought about coating the headers to make it look a bit rusty like OEM. I just need something to push me over the edge before I buy it.
I spoke to someone at ss headers and he said he has never seen stock headers that were soo restrictive and he couldn't believe the power the motor was producing with the terrible stock headers.
Yea the stock manifolds are horrible thats why you can realistically gain 20wheel off headers.
Next time I'm in the neighborhood I'll hit you up, so you can see how hard it is to tell they are there to the untrained eye.
