Dynoed my 02' gs 430
https://www.clublexus.com/forums/sho...d.php?t=378654
It was a Dynojet dyno ! and i was actually inside the car ! i did about 6 pulls and the car kept reading higher and higher each pull for some strange reason first pull 219rwhp/254rwtq but between the 5th and 6th pull i disconnected both front and rear batteries and let the ecu reset and the 5th/6th pull read 231.88rwhp/269.15 rwtq! itried leaving it in 2nd and it still shifted to 3rd, then i tried 3rd gear a couple of times and it still shifted into 4th ! and yes the VSC was off on all pulls ! so i got my afc !soon as i get an intake i'll install both and head back to the dyno and get it tuned and see what happens and i'll post both dyno sheets before and after piggyback !
See If they will give your dyno on a disk/jump drive You can display and compare them different ways.
