Is Royal Purple Max Gear O.K. to use in the Supra 3.76 LSD?
I have read a couple of previous posts and some say that it is NOT GOOD to run a differential fluid w/friction modifiers in this type of LSD; it's the torsen style. I had this thing installed a little over a year from now and ever since DAY 1 the car makes sort of a dragging/slight grinding noise on turns at low speeds. Also, lately in the morning on initial slow acceleration it makes a low tone; almost like a slight vibration...which goes away once the car gets warmed up.
I am thinking of ditching the Royal Purple and going with something else. Did I break anything? I hope to god that when I replace this fluid that I don't see little metal pieces come out.
Was this fluid wrong for my application?
I would do the flush then take it from there. I doubt you bought it new, so who knows what kind of abuse that thing received, however; I thought that LSD were one of the toughest out there, so there shouldn't be much wrong with it. Also, it does not need a friction modifier, but doubt it will hurt it if you use an oil like red line that already has it.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Anyways, try that red line stuff. It's suppose to be the best out there.
The royal purple max gear oil should not give you any problems. I used it in both my GS300 and Supra and have no problems at all. Make sure you run a 75w 90 and not the 80w 140 as that is too thick for this type of rear end. Also, wanna sell me the set of axles that those rear end came with when you bought it from team lexus. I could always use a spare set as I've broken them in the past from wheel hop.
Rock-a-Lex
Performance
23
03-17-10 03:33 PM
Rock-a-Lex
Performance
10-21-08 05:12 AM
