NeeD MoRE PoWER !!!!!
yea i guess i was being too optimistic with the injectors ...thanks mac d i just wanted to avoid fuel guage issues im hearing about and also keep it simple im go check out my.is i think there are some boostedcali guys over there
Stock injectors won't support that much power safely. Off the top of my head they are roughly 280cc which won't break 300hp safely. You need at least 310cc to make 300whp which is still cutting it close, preferably you should go with 440cc which will be able to make 350 safely and leave a little bit of headroom if it's needed. Don't forget you will need to upgrade your pump as well, either a OEM Denso Supra TT pump or a Walbro 255 pump will work fine at those power levels.
dustinleeh
Performance & Maintenance
22
01-27-12 11:23 PM
