Oil on spark plugs?
Old 01-03-09, 11:25 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Default Oil on spark plugs?
OK, I just got my headers installed (please see other thread on results) along with new plugs and some other stuff. I asked for all the old parts back just to see their condition. I was ASTONISHED on how bad my old TM plugs were; they were COVERED in oil! All of them! The oil is VERY VERY thick and sticky almost like tar.? They have been in my car for about 2.5 years now.
About 5 months ago I used Seafoam through the PVC valve and in my gas tank. Now, I read that you are supposed to replace your spark plugs no later than 1000 miles after using this Seafoam because I guess it kills your plugs. I didn't get to change them until about 5000 miles later.
Guys, did I damage something? The car drives great after the install of everything. I'm just worried that there is something seriously wrong due to how my spark plugs look. Please advise! I will post up picks of the spark plugs when I get a chance.
Old 01-03-09, 11:50 AM
fordsvtmfl
fordsvtmfl's Avatar
pretty sure oil on plugs is a valve cover gasket issue..at least thats what i was told
Old 01-03-09, 12:08 PM
ElitistK
ElitistK's Avatar
you are never suppose to put seafoam in your oil in the first place.
Old 01-03-09, 01:47 PM
jcat_350
jcat_350's Avatar
^^ +1, seafoam should be used in the gas tank, and brake booster line, and one other place i can't remember right now.
oil on the plugs, since you have a gs4 (coil on plug) is more likely head gasket than valve cover gasket, but seeing how you put seafoam in the oil it probably just thinned out and made it in there through blow by.
Old 01-03-09, 05:29 PM
macd7919
macd7919's Avatar
I wouldn't worry about it, it is 99% likely that it's just oil seepage from the gasket between valve cover and plug. It happens on most cars as they age.
Old 01-03-09, 07:13 PM
Rock-a-Lex
Rock-a-Lex's Avatar
...now, I'm REALLY confused. I read in MANY places that you put 1/3 in the fuel tank (did this), 1/3 in the oil crank case (did NOT do this) and the remaining 1/3 bottle introduced through the vaccum lines via brake booster or near the PCV valve and have the engine "slurp" it up slowly (did this as well). I have read these directions over and over again on these very forums! I need further clarification! The car drives great though!
Old 01-03-09, 07:34 PM
jcat_350
jcat_350's Avatar
i would use the brake booster over the PCV, but that's just me.
honestly, save for a complete teardown i really don't have much confidence in seafoam really cleaning out the engine like it says it will. I'd probably just use fuel system cleaner, or even restore if it got that bad. I have doubts about seafoam from my maxima days.
Old 01-04-09, 09:18 AM
Rock-a-Lex
Rock-a-Lex's Avatar
well, I will never use it again...for sure. I just want to make sure my car isn't damaged. What signs/symptoms should I look for?
Old 01-04-09, 09:51 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Pics of spark plugs...
Old 01-04-09, 09:52 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Old 01-04-09, 09:53 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Old 01-04-09, 11:45 AM
jcat_350
jcat_350's Avatar
ooof, nice haha.
if you put the new plugs in and shes running fine, i dont think you should have any problem. The seafoam will all burn away and it shouldn't adversely affect you that bad.
the engine has a measured amount of blow-by (old oil being sent into the intake to be burnt off) so your plugs after a while will get oil build up on them after a you put some miles on.
Old 01-04-09, 04:40 PM
Rock-a-Lex
Rock-a-Lex's Avatar
Thanks for the input J...
Old 01-04-09, 09:06 PM
GS FONZy
GS FONZy's Avatar
That's your valve cover gasket. Look at where the oil is on the plugs, the spark section is dry, your car is fine.
Old 01-05-09, 10:11 AM
Rock-a-Lex
Rock-a-Lex's Avatar
So, is this normal? Or should I fix this ASAP...as in, fine now but potential danger later?
Quick Reply: Oil on spark plugs?
