Joe z intake
Joe z intake
i got a Joe z intake today, people told me is the same as F sport, however the air box is different, there is other hole in the f sport air box, so i was wonder how do i make that on my stock air box, and where is the hole?
Are you talking about the intake tube....or just the intake filter box? I was told that cutting more holes in the intake box will give you more air, but hot air from the engine compartment (hot air is less dense than cold air...denser air gives you more O2 to burn, thus more power)....unless you route some kind of cold air tube to the extra hole that you cut out....I'm not sure if you really need that much more air because the ecu might not know what to do with it....it would have to be reprogramed....the Joe Z intake tube....the one that goes from the air box to the intake manifold only serves to "clean up" the air turbulance caused in the OEM intake tube (no ridges...no turbulance). This might all be BS for all I know, but it made sense to me at the time....lol
The stock airbox/tube already provide more volume of air than the engine is capable of using.
The extra hole adds absolutely nothing whatsoever but sound.
There's at least 1 or 2 threads if you search on cutting your own extra hole if you want the sound. It won't add any performance though.
2IS OG
A group of us actually tested an F-Sport intake against the Joe Z setup (box with and without the extra holes) at a 1/4 mile drag strip last year, and we consistently got better times with the Joe Z setup (box without the holes) over F-Sport setup - so unless you're looking to go slower, I'd leave the box the way it is.
Javier
Javier
Javier
Javier
hahah thanks guys i think i can forget about making the hole on the intake box, i have not put on my intake but today i show an 06 STI what sup, i was faster then him by more then half of the car. =)
