For speed signal I used a w58 speed sensor. Not a 100% fit but it works. Some say the 2j ecu does not need a speed signal but I have done a lot of other swaps who needed a speed signal For correct running,
Do you have any picture of it, how many wires speed sensor you are using for w58. I have connected 3 wire speed sensor (pic1). where one goes to power and other ground and the last one direct to gauge. but can't connect to ecu as its have different volt. originally Aristo gear box have 2 wire sensor.
pic 1
please help me with picture?
i have swap aristo engine with w58 gearbox in gx100 chaser. here is the pic
gx100 2jz
thank you very much for your support i really appreciate.
