Joez with hks hybrid filter..
Need clublexuses help. iS THIS NORMAL WEAR AND TEAR?
I had the joez on for about 2 yr now with oem filter on for 1 year
and the hks hybride filter one for the last year.. just wondering if im suppose to see black residue in the intake??
keep in mind that the first year with oem filter i never saw this black stuff on my inside the joez intake....any one know what the cause might be? or if its normal? There is also some weird silver ring on the inside of the sleeves is it melted?
Tech Info Resource
It's dirt from an ineffective air filter. Why are you surprised? Better flowing filters let more dirt pass. It's pretty fundamental.
yea that what i was thinking.. but didnt want to think that .. .the 2nd filter use to be white and now its pretty black/grey...will it be harmful to our vehicles? or can it handle it?? i know dirt in the engine is bad.. just don't know the severity of the dmg it could cause?
Tech Info Resource
Do an oil analysis to check for silicates.
Received 1,064 Likes
Yeup.. Very Normal... well sorta...
Actually what your looking at is Oil Vapor being sucked back into the intake tube, to the throttle body, to be burned up...
..The vapor travels via the PCV Vacuum Line, which comes from the top side of your Engine.
Then the subsequent dirt particles that flow through your engine air filter and into the tube, sticks to that accumulated oil vapor.
What kinda of engine oil (brand & weight) are you using and how much are you putting in???
Also, your "High Temp Fiber Reinforced Silicone Sleeves" are not melted..
Thank You
Joe Z
Thank You
Joe Z
Damaster32
03-27-12 06:01 AM
