Injen/Fujita CAI
Hey i'm looking forward to adding a CAI either Injen or Fujita since that's what most people seem to recommend. Is there any place i can get it for a good deal? And is there more to the installation than swapping the air filter with the CAI, such as a chip swap, changes in ECU for the A/F ratio?
Thanks!
Thanks!
I've had the Injen and Weapon R both installed on my car and only had the check engine light come on when I didn't clamp one of the brackets on tightly enough. These are plug and play intakes so once you install *correctly* you should be fine.
As far as the differences in product, I perceive them to be about the same. I had a richer sound with the Injen than Weapon but both did the job. You can probably find some really sound deals on a GS300 intake on eBay since the demand for those products is not a great as years past.
Also, they the search function. This topic has been covered before.
Here is a link for you to check out:
Fujita Intake
hmm i've been looking around for some CAI for the 2001 GS300 and it doesn't look very popular; i can't find any. But i did find a lot of Short Ram Intakes for the car from both Injen and Fujita. I did some research on it and it seems as if CAI's are better than Short Ram's regarding performance. Is it true?
I have a 2002 GS300 and I'm also looking for a CAI, and from what I've read...I would reccomend a CAI over a short ram because I think a CAI gives a slightly larger HP gain. Look on ebay for one because I can't find anything online besides short ram except for on ebay. And I'm wondering if anyone has advice for me...I'm considering adding a performance chip once I install a CAI.
not sure if the 2G GS can support a CAI since the OEM air filter does not utilize a resonator that goes inside the bumper like most other cars... since it uses a ram air scoop from the front grill to direct air into the filter box from the front, there isn't anything coming from the bottom..
i can be wrong though as i haven't taken off the front bumper or peeled back the wheel liner to look inside the fender... i would guess this is possible since the NA-T guys are running piping for their intercoolers somewhere...
