My car is on strike
My car is on strike
Okay I got my turbo installed and now I'm having so many problems .When I start my car it wont idle and I have to rev the gas to keep it running or it would die on me. I had to replace my maf sensor and I bought a throttle from a member on the forum and still no luck .Deception stopped by my house and helped me re- wire my fic and I'm using his basemap because the shop did it *** backwards causing the the car to not even start. Last night I checked my plugs and they were the wrong plugs so I put in some supra tt plugs gapped at 0.28. The car still wont idle it dies unless I hold the gas and it struggles from 1000-4000 rpm and after 4k rpm it breaks up and i found out I have a coolant leak coming from the rear of the motor by my flexpipe and trans pan HELP ME I'm sick of this ****!!!!!! I'm running a t61 turbo, aem fic, 2.5mm hg ,walbro pump stock injectors,I have 550 rc's but I'm using stock ones for tuning and uego wideband and a 50 mm wastegate.
The FIC strikes again!!! lol but seriously...a word to those who are planning on turbocharging in the future...this makes what, 5 or 6 ppl now who all are having FIC problems? So whether or not you COULD make it work...save the headaches and dont even view the FIC as an option...you will be far better off...trust me
Who did the headgasket? Those symptoms sound like it could be off timing.
There aren't any coolant lines near the tranny pan and flex pipe. A common place for a leak is behind the head where the coolant meets the head right by top of the firewall on the head. Get the car on a lift or jack it up, have a nice bright flashlight and you should be able to find the trail of coolant from the source. Also, it may help to get the car up to temp before hand so the lines will be pressurized and you have a fresh trail.
If you totally removed the FIC the car should start and idle fine even with the turbo installed. If you still cant free rev cleanly with the FIC removed that eliminated the issue as a tuning one. I haven't tuned an FIC but it seems like a simple device (no timing control etc...) Unless there is something that could be majorly screwed up with tuning than it should be ok. What is your wideband reading at steady throttle?
Before you do that make sure you have enough fuel in the tank. Walbros tend to sit higher in the tank so I usually keep my fuel gauge above 1/4 tank. Sounds funny but just humor the idea and put a few gallons in the car if it's not full now.
Fwiw: I can't hear my pump with the back seat in place.
um ok...idk who peed in your cheerios, i was just pointing out the fact that it seems like every car that has a FIC inst working right, and yes..i desperately wanted to make the FIC work....so after 2 months and a couple hundred buck when i finally gave up on it...it should tell you how little faith i have in it...and to those who want to take the warning...great...others..thats fine 2. and idk how i came across as "king of standalones" but w/e
lol see Brian...im not the only internet psycho! lol
I'm not mad at you homie but if you read my original post I only stated that I had a fic and that it was originally wired up wrong , never did I say that my fic was the problem you just assumed that it was the problem . and as far as me being psycho you're a piece of work , I'm suprised you are still here considering all the third degree burns you've received from getting flamed for asking the same stupid question over and over that members have already given you the answers or you get offended because it is not what you want to hear. And now you're talking like you are the new Jeff Tsai or as if you have the most envious turbo setup on the boards running a full Motec system AND YOURE PUSHING 1600 HP AT 7PSI ON PUMP GAS AND 2 BOTTLES OF OCTANE BOOSTER but you have never even posted one pic of your car and you are the king of standalones because no one really pays any attention to you so you are in essence a standalone. So don't play with me HOMIE BECAUSE I WON'T FLAME YOU I WILL CREMATE YOUR BIPOLAR *** now lol on that pimpin
The pump is working ,I removed the white harness on top of the pump and tried to start the car and it will not turn over once I reconnect the harness the car fires up but it would die out
well, this is alot tooo read but my fic runs fine....t60 turbo with 1.3mm hg upgrade and boosting up to 13psi with no problem....it could be alot of things...i installed and tuned the fic at a dyno shopped.. with NO PROBLEM...except form one bad o2 sensor.. but that was an easy fix it..u guys with fic's should try buying the wire harness at boomslang. its plug and play. less hassel...the main thing with turbo is to install it right.. always double or triple chech everything...when i started installing my turbo i had alittle issue with idle.. alot of people said this was not the issue but it was... the 2 primary o2 sensors.. i had 1 sensor welded on cylinder 1 manifold and the 2nd on cylinder 6 manifold and the 3rd on the exhaust down pipe..that took care of alot.. and my car is still running good..still about 15% rough idle but already change the bad o2 sensors already so just need to take it back for final tuning and my car will be 100%......BTW my car is a daily driver....so i'm still happy with the route i went...this is my 2cents... those of u think that the fic is a bad idea...i think u guys are not installing either the turbo or the fic right........
