6 speed transmisson
6 speed transmisson
i wanna know how much it cost to put a supra 6speed transmisson in my 93gs300
and i wanna know if a auto trans from a supra '
fits right in 93gs with out modin it
Cut,weld and bend
from what I seen the automatis trans is much thinner and to put a 6spd in you got to cut and bend some of the transmission cave so that it does not drag on the floor.Im planning a full Supra engine and tranny swap on a 1995 GS300 so will see if its alot of work.
Re: Cut,weld and bend
Comming soon I hope
I plan on having pictures and step by step instructions to my complete swap ,I should slowly be able to get the parts I need over this year.I will be doing the full swap myself and cant wait to have all that mad power for a nice summer car.
Re: Comming soon I hope
Do you have the car already?
2jz-gte
Hey Im doing the same swap this summer, already have the car a 94 gs3. I plan on modifying the firewall to accomadate the stock twin turbo sysytem w/ manifolds. I dont want to go to a single turbo. The six speed is an opt at this point although I am lookin at the auto as a serious opt too.
James
James
GS300 TT Baby
Good the more 2JZGTE guys we get the more BMW ***'s we get to destroy.I am also planning on doing a full swap including the stock twins but so far the swap looks fairly simple other then the Tranny.
Fairly .....
Fairly simple ? Yes and No the stock twins wont bolt in because of firewall clearance remember the V300/aristo is RHD and has a different firewall than ours. Therefore either cut and move the firewall back the necessary amount or go ghetto with a BFH and smash it back the necessary amount. Simple yes, just time consuming. As far as the tranny goes very little work has to be done to the tunnel to get a 6spd to fit, but youll need the clutch pedal assy. and master/slave setup with custom lines etc...
More to come ..
I know have all the parts I need for the swap and im just looking for the car to buy.One thing im not sure about is how this Aristo computer I got with my front clip will work with a 6spd getrag and how it will take to upgardes like injectors and turbos.Im hoping it all goes smoothly and that when its in the car it performs just like on a stock Supra.Im not sure if i should just get a supra ECU and hook that up instead of the Aristo one I got.
Baby ///M3
Performance & Maintenance
12-06-03 09:03 PM
