first time using "Lucas" injector cleaner, got 378 miles on full tank
#31
Just keep in mind there is a point of diminishing return. If you see an improvement, it's most likely because the injectors weren't performing optimally. Those who see little to no improvements probably already have nice flowing injectors Either way, it's nice to do some cleaning once in a while.
#33
^^yeah i used 3oz on a halftank just to clean it out. then i went a full tank and put in about 9oz. i think i lost some mpg. i used to get 280miles a tank. looks like ima need a fill moro at 250miles. is this possible? did it loosen the gunk and clog something else?
#36
I haven't use it at all, but on my trip from Mpls to Stl, we averaged about 80-85 mph which isn't great for gas, but I hate long trips. But every time we filled up I was getting between 22-23 mpg, best I've gotten was 24, and worst was 18. All in all, I would say all there of us have similar mpgs readings.
#37
I threw some STP fuel injector cleaner in a full tank of premium a few weeks ago. I went from 17mpg to 19mpg. I mainly do around town driving (45-55mph though), though I have just started using Shell premium even though my dad thinks it is a waste of money. Car is in the shop right now getting a severe brake failure fixed, but once I change the oil I'll throw the other bottle of STP in (it was 2 for 1).
This mileage seem typical for a '00 GS300 with 134k miles?
#38
I just drove from Minneapolis to St. Louis and back, and that is about on par with what I was getting on the highway. It was about 80% highway, 20% city, and I got 350+/- when my light turned on, but that's with 4 gallons left for the reserve, and averaging 80-85mph with the AC on the entire way.
#42
Are these the ones you guys are all talking about:
5.25 fl oz bottle
32 fl oz bottle
Is the 32 fl oz bottle better since it says "fuel conditioners" on it and the small bottle doesn't have that?
Thanks in advance for your time and help.
5.25 fl oz bottle
32 fl oz bottle
#43
That's the one. If you're gonna use it often, find the gallon size for $28 and purchase that. You get more for your money.
#44
I tried this about several months ago when I cleaned my MAF & throttle body. It's kind of hard to tell if it was any good since I cleaned the MAF at the same time. I will try it again when I change my oil soon.
