hello, 2jz tranmission help! (jdm)
i want to do a 2jz swap the jdm gte to my 98 gs300 the motor is easy my dad can import for me, but i heard the transmission is going to give me problems, because from electronic to the straight up and down old school shifting like the older camry's, its going to be automatic. i just want to know how you do it, or does it bolt right on, that's what i heard i had to mod but to mod what i am not sure. Thanks in advance
nope non vvti, i try to avoid getting the usdm gs300 vvti too, i heard it will have problems with electronic later on when i swap it. yes auto to auto, so anyone can drive it i guess. and less hassle .
because i heard the wiring is different for sure but the usdm car with the vvti, but i was just going to throw in the regular 2jzgte. i still want to know about the transmission mod
okay vvti on the usdm gs is what year? and i want to drop in 2 hks 2835r turboes =/ but it cost a lot. if i am getting the vvti from japan, what car is it off of? second gen gs vvti?
I have the 2JZGTE non vvti motor in my 2001 Lexus GS300, this is not a direct swap by any means. Motor mounts won't work, A/C won't work.. lots of issues. get the vvti motor and call it a day.
I wanted the non vvti motor myself. I'm just glad I had an electrical engineer as my installer / tuner. Grip industries helped me out with the motor mount issues. I'm loving the GS300 now, 18 psi on pump gas with the manual transmission, PTE74mm turbo, and 272 cams with a stand alone makes for one hell of a ride. I took my car to the scales, came in at 3730 with a 1/4 tank of gas and the spare tire / tools in the trunk.
so the vvti would bolt right on and a/c will work? because in southern cali it get really hot at times and i need a/c my bro's dc2 doesnt, and im pretty big so it is even hotter. i just want power and bolt right on, and the wiring needs to be modded correct? and i was wondering which one is faster? vvti or the non vvti? my dad is looking for a vvti one for me i just need the car, so any year will work? like the 98-05 just not the v8 version?
