Transmission problems IS350
Old 01-05-15, 12:21 PM
cobalt293
cobalt293's Avatar
I have followed that process, but the strange things is that it´s not slipping in D (if engaging kickdown on 2500rpm it slips and goes to redline, 2100rpm kickdown is fine).
Old 01-06-15, 10:42 AM
cobalt293
cobalt293's Avatar
Some feedback..
Teared down the Valve Body and dissasembled it fully to see if there was any blockage and also test all of the solenoids. I didn´t remove all the pistons but checked that they moved. What I saw was that piston B1 accumulator was rather worn full of scratches (don´t now if that could be the problem) part nr 3542460030.
I can drive the car forward, but it sleeps when i do kickdown on higher gears. It engage reverse.. but doesnt have the strenght to move forward..
Haven´t had the possibility to test the hydraulic line pressure yet.
I have a error code P0894.
I have no warranty.. so it looks like i´m aiming for a new transmission
Any ideas are most welcome.
Old 01-06-15, 11:47 AM
kornpeef
kornpeef's Avatar
just checking on that process. your sure the trans temp fluid was at the right temp before you drained the over flow drain plug right? i believe the temp range is between 115-133 deg F. and that you let it come to a drip before closing it off. Im not quite sure which year it is but there is a couple that the manufacturer messed up on the level design and now have a TSB and special service tool to get the level right. be short or over even 1/2 a quart can cause issues.
cwtt
08-08-17 01:45 PM
MWIS350
05-28-15 01:56 PM
era87
01-20-09 01:11 PM
omgitsroy
09-07-06 07:27 AM
Quick Reply: Transmission problems IS350
