Transmission problems IS350
I have problems with my transmission. My reverse doesn't work at all. When I switch the R position my car doesn't move back at all. Does anyone have ever problem like me? And if anyone knows EXATCLY which transmission IS350 has AISIN A760E or AISIN A761E because I can't find the confirmed info. By the way my car has only 28000miles and 2006 year and I have already this problem.
Thanks!
Thanks!
Tech Info Resource
Thanks!
Thanks!
Hi,
I now this is a rather old post..
I´m experienceing the exactly same problem. Did you got the answer what the problem was, me and my dad is going to inspect the solenoids tomorrow.
Have also experienced some strange shifting overall (actually slipping when kickdown).
Thanks in advance
Rgds.
Mikael
Thanks in advance
Rgds.
Mikael
take it to the dealer. reverse is a mechanical input to the transmission. if you dont feel the shift or it doesnt go in most likely need a new transmission. the dealer might drop the trans oil pan to inspect for debris.
Actually it goes into reverse but no strength at all (and it doesnt make that sound.. it´s just as it´s slippin).. i´m rather interested so I read the TIS documentation and a stucking solenoid (S1) could make the reverse unusable...
As my dad has is a mechanic were going to tear down the oil pan and clean and go through the solenoids.
