Can't get Tranny drain plug out
You can get the filters from your local auto parts store. I do these for people all the time and it comes with the filter and rubber oil pan gasket for around $40. Only thing you have to pay attention to is that you must remove all the old silicone prior to putting the rubber gasket or else it won't seal properly.
The one I get from the auto parts store uses a rubber gasket on the pan and not a cork gasket. So far I haven't had any issues with the rubber seal, if it was cork I would toss it in the garbage as well. I goto transtar occasionally, but it's about a one hour drive for me so it's a little out of the way. If I need the parts in a pinch, I just pick it up at the local parts store if they stock it. Some of the other guys here on the forum don't have a Transtar or rebuild part supplier nearby, so I was just quoting what they would generally pay.
Tiagz
03-29-23 11:57 AM
