? about gs300 diff
I have a question, I'm gonna be putting in a 01 gs300 diff into my 03 gs430 i've searched and came up with this
From jeffTsai
>>Ran into a few problems lol. Seems as if the drive shaft for the GS400 is slightly different than the GS300. The flange at the very end of the driveshaft that mates to the rear diff isn't the same size. The GS300 one is slightly smaller...only by like a few millimeters, but that's enough to prevent it from bolting up.
What will i have to do to make it fit? or can it fit at all? do you guys know anyone with this setup? would i be able to feel any difference at all in acceleration?
Thank you very much
From jeffTsai
Thank you very much
Trying to understand...
OK, so 400s and 430s have a 3.29, the 300s have the 3.92, and the Supra one everyone wants is a 3.76, right?
The 4XX guys can swap in a 300 pumpkin for supposed faster acceleration, but it does NOT have LSD, and gas mileage is slightly worse than with the Supra unit.
Am I understanding the big picture?
You just need to swap over the companion flange. After that, torque the nut down and check preload torque on the flange. Once that's done, stake the nut and you're finished. Should only take about 5-10mins to do.
I have a quick DIY on my site www.ProjectGS.com/DIY
It's under Engine/Drivetrain first link in there for swapping differentials.
Denut-L, since your 430 rear end is already in there, why not just drop the 3.92 ring gear into the existing pumpkin, that way you don't have to deal with the companion flange. I actually have a GS300 diff sitting apart in my garage waiting for my LSD insert. Other than the companion flange, it's the exact same, I used a 3/8 impact gun on mine, and it worked fine.
Anybody know what the torque spec is for the flange nut?
You are correct, the only minor correction is that the 400/430 diff is 3.26, otherwise your above statement is all correct.
I'll try swapping the diffs first and if i decide to install lsd later i'll hit you up for some diy info.
Thank you very much for all the info..I'll be on my way to pickup the diff now
Maybe this has already been covered in the archives, but is there a way to install LSD without swapping the pumpkin? I was told once the swap to a 3.76 diff didn't help acceleration all that much and gas mileage suffered by about 2-3. I was just wondering if there was an inexpensive insert or something to make it LSD...?
PS. Talking about a 400.
If you are right he MAY be the ONLY person that has mated the 3.92 gears (from the GS300) into the Supra TT LSD rear and installed it all into the V8 Lexus GS.
...interesting
...Really?
He never mentioned that in his previous posts. Only mentioned that he has the 3.92 rear setup.
...interesting
...interesting
This is to JeffTsai what kind of 35mm socket did you use to get the flange nut out? From your diy page it looked like you had a great neck, was it a standerd socket or axle socket?
I could only find a 35mm deep socket for the axles and it would not fit all the way down cause it's too big. only 1/4 of the way down![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
I went to sears and they only had 32 n 36mm![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Please lmk as i'm stuck on this.
Thank you
Thank you
"The internal of the Supra TT diff. is very much the same as the GS300/GS4."
I don't see how it is that similar to the stock GS diffs because the Supra TT diff utilizes a Torsen style LSD inside. It functions completely different.
"I've seen a few people who have mated the TRD LSD with the GS300 ring gear for better acceleration."
I have seen this too but be advised, a TRD LSD is NOT a torsen style LSD! I too researched this option of just throwing this part into my stock GS400 open diff because it worked great and was cheaper but the install was more costly and wound up being close to the same as just buying a complete Supra TT LSD unit (for an added benefit the Supra TT LSD came with shorter gears). Oh and the drop in TRD LSD unit does NOT add acceleration at all! It simply allows you to put more even power down to the ground and if you only have a stock GS300...it is a rather pointless addition.
Thank you
Thank you
The torque on the nut is 249ft/lb or less. It can vary because you need to set it accordinly to preload on the flange. On a new bearing the preload is 8.7-13.9in/lb, on a used bearing it should be 4.3-6.9in/lb.
Wait, your combining two sets of separate thoughts...![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
I don't see how it is that similar to the stock GS diffs because the Supra TT diff utilizes a Torsen style LSD inside. It functions completely different.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
I have seen this too but be advised, a TRD LSD is NOT a torsen style LSD! I too researched this option of just throwing this part into my stock GS400 open diff because it worked great and was cheaper but the install was more costly and wound up being close to the same as just buying a complete Supra TT LSD unit (for an added benefit the Supra TT LSD came with shorter gears). Oh and the drop in TRD LSD unit does NOT add acceleration at all! It simply allows you to put more even power down to the ground and if you only have a stock GS300...it is a rather pointless addition.![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
