03 Gs430 ecu help > afc Neo
I'm almost done installing the neo then comes hooking up the wires to the ecu and now i'm stuck. Looks like the wiring diagram is different from the gs400
does anybody have the wiring diagram for the afc neo to the 430? I tried searching but it's all gs400 and gs430 with srt intake and safcII only.
Thank you
Thank you
Just curious would it at all be possible just find the same output of the ecu, or what? I am sure there is a difference, however I'm thinking that it is just another output, I am just guessing. I have never installed one before, but if I knew what it was i'm sure I'd figure it out. You around South Minneapolis at all?
I called Full Blown motorsport and they wanted $170 to wire up the neo to the ecu. If i could just find the ecu wiring diagram i could hook it up myself..but no luck anywhere.
3uzfte the gs400 only has three rows of pins up and down, now the gs430 has 4 rows of pins..I'm not sure if the pins i'm looking for are in the same spot as the gs400 but I'm not gonna take any chances.
I'm in st paul btw
Anybody with the 430 ecu wiring diagram wanna help a brother out
I'm in st paul btw
