GS300 Heatshield
Hi Guys, I just got done with the first production proto for the IS300 and it should fit the GS300 as well. Targeting a $100 price tag, this heatshield is made from 16ga 5052 Aluminum and the F braces acts to really make this a rattle free device. Based on testing this should reduce intake temps between 20-30 degrees depending on ambient conditions and install could not be easier. Just loosen the rear bolt that holds the ground and hose clamp, slide the sheild onto the bolt, install the front bolt and tighten both. Intake removal is not required. Please give me feedback on what you GS guys think.
Partial anodizing will be avaiable at a later time. I am just building the first 5 units at the moment.
![](http://i88.photobucket.com/albums/k195/Figbline720/HEATSHIELD/DSC07554.jpg)
![](http://i88.photobucket.com/albums/k195/Figbline720/HEATSHIELD/DSC07557.jpg)
![](http://i88.photobucket.com/albums/k195/Figbline720/HEATSHIELD/DSC07558.jpg)
![](http://i88.photobucket.com/albums/k195/Figbline720/HEATSHIELD/DSC07559.jpg)
![](http://i88.photobucket.com/albums/k195/Figbline720/HEATSHIELD/DSC07560.jpg)
![](http://i88.photobucket.com/albums/k195/Figbline720/HEATSHIELD/DSC07563.jpg)
![](http://i88.photobucket.com/albums/k195/Figbline720/HEATSHIELD/DSC07564.jpg)
![](http://i88.photobucket.com/albums/k195/Figbline720/HEATSHIELD/DSC07565.jpg)
![](http://i88.photobucket.com/albums/k195/Figbline720/HEATSHIELD/hsF-rend1.jpg)
![](http://i88.photobucket.com/albums/k195/Figbline720/HEATSHIELD/hsF-rend2.jpg)
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
I should have these heatshields ready in two weeks for General Avail. Still working out the process for the first 5.
Fig
__________________
Updated pics. These are now listed on my site.
$135 limited quantities
![](http://i88.photobucket.com/albums/k195/Figbline720/HEATSHIELD/multiano/_IGP1577.jpg)
$100
![](http://www.figsengineering.com/IMAGES/HS/HSprod.jpg)
Fig
$100
Fig
__________________
Looks great. Nice engineering. Is a 20-30 degree drop in temperature enough to make a noticeable performance difference in conjunction with an SRT or CAI? I know the cooler the better but was curious if this mod would be noticed in the accelaration? Thanks.
So far I have only done black and blue and all black. I will shoot for a Red black combo, but with SEMA coming next week, tons of snow here I am tight on time. So probably in a few weeks for color combos. I only have black in stock and only about 2 at that.
the anodized versions are not welded, they use high temp silicone on the bottom and a single rivet on tip combined with the tab in slot features already there.
Nothing on the v8 yet..I am just barely getting these done, so a little more time and a test subject meeting are needed.
Fig
Fig
__________________
I am not sure, I would have to see if the stud location on the front is the same, I am thinking it should. Do you have pics?
Also here is a pic from a black installation with other powdercoated parts installed.
![](http://i86.photobucket.com/albums/k91/beanDS/IS300%20Pics/Figs%20Heat%20Shield/FIGSShield_2.jpg)
I will have 4 black parts in stock next week, and they will go fast. Ordering is open opn my products page www.figsengineering.com
__________________
