Intake
Intake
Hellog folks, I came across this intake. Have anyone of us ever used this intake and how was the performance? I know that the SRT with race ecu is what most members here used, but it is expensive. Any advises are welcome. Thanks.
I believe if you run the srt intake without the ECU the CEL will come on because of the diameter of it. I had ran a cheap K&N intake off ebay (like 40 bucks) for a few years no CEL or anything. Regardless whatever you do you would either need the ECU from SRT w/ the SRT intake or a AFC in order to get all the benefits and/or any HP gain.
If you run the SRT without the ecu, you will get the CEL on immediately. You car might/might not start and if it does will probably idle very low/rough. If you are getting the SRT intake, get the ECU as well.
