Plug Change-WOW-HUGE DIFFERENCE
#31
Originally posted by GS430 GUY
RA,
I thought they were Denso Iridium plugs as well.
Ragarding changing the plugs, I think Percy changed his plugs to a brand called Torquemaster, if I am spelling it right, and he said he felt a noticeable difference compared to the stocks. I am happy with the stock plugs, but I am starting to think maybe I should change the plugs. Quit confusing me guys
RA,
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#32
The One
I have a GS300 and have a 60k mi service in a few thousand miles. They said that the plugs are usually changed if I don't have the Iridiums, which I don't think I do. Would these work on GS300s? Would these be good replacements?
I don't know. The price of the service between getting plugs replaced and not is about $300 ($699 vs $999). I don't know what else they do to warrant $300. The plugs are not worth that much.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#34
Moderator - Electronics Forum
Originally posted by Hermosa
Did he swap out new plugs or did he replace the plugs once they are old? Of course it would make a big difference if he put the Toquemaster plugs in after he was running on very old and corroded stock plugs. I would be interested to see if he had new stock plugs and tested the car immediately before he tested with the other plugs.
Percy
#36
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
I'll give you an example of the very first thing I noticed when I switched to the torquemasters-the tach charged to redline imo much faster and more fluidly. It was like someone sprayed some WD-40 on my tach needle.
Also, I know our stock GS 4's are quick, not blazing...BUT, after adding my SRT intake/ecu, Borlas, and Torquemasters, I sometimes get that "oh **** feeling" in my stomach because the car is going just that much quicker than it was at stock. I firmly believe the torquemasters provide the definitive kick that my car's breathing desperately needed.
#40
Plus, platinum/iridium is a relatively poor conductor compared to the standard nickel and copper.
just some stuff to think about...
Percy
