Taking out intake
Old 11-10-09 | 06:30 PM
MrHarris's Avatar
MrHarris
Default Taking out intake
I'm taking out my Fujita intake. Do I need to reset the battery or anything or can I just drive off after and everything will adjust itself?
Old 11-10-09 | 06:46 PM
Initial G's Avatar
Initial G
Please correct me if I'm wrong but I believe once you remove the fujita and replace it with the OEM, you can drive and everything will eventually adjust itself.
Old 11-10-09 | 07:17 PM
MrHarris's Avatar
MrHarris
I just tried turning on the car after installing the OEM intake back and the cut shut off. I tried turning it on again and the the VSC is disabled and I got a CEL.
EDIT: I forgot to plug in the mass airflow sensor I believe. I started the car and it works fine but I still have a CEL and "Check VSC" light. Anyone know how to get rid of it? Do I need to goto the dealership or can I just reset it w/ a code reader?
Old 11-10-09 | 08:04 PM
alan003's Avatar
alan003
I think someone on CL said if you plugged everything back and drive around. the codes will disappear.. but not 100% sure
Old 11-10-09 | 08:12 PM
MrHarris's Avatar
MrHarris
I just drove home, about a 10 minute drive. The codes are still there! Car feels fine though.
Old 11-10-09 | 08:25 PM
someboy's Avatar
someboy
yeah you will get errors and your traction control and VSC will be turned off for a while. but eventually, the ECU willreset itself. for me i drove my car for a while then restarted it for about 2 times and everything was back to normal.
Old 11-10-09 | 08:36 PM
ChrISF's Avatar
ChrISF
while your car is off, hold your trip reset button, hit the start button twice, but dont turn on the car car. keep holding the trip button until the flashing dashes on the trip screen go away. let go of the trip button and turn on the car. your problem is solved!
Old 11-10-09 | 08:56 PM
MrHarris's Avatar
MrHarris
^ wow this worked! Thanks a bunch!
Old 11-10-09 | 11:24 PM
Ghost ES3's Avatar
Ghost ES3
or just pull the ecu fuse out and plug back in...that will reset everything as if you disconnected the battery....
Old 01-04-10 | 09:49 PM
SoCal35's Avatar
SoCal35
Whoa... I just installed my JoeZ intake and had the check engine light and VSC light come on. After driving a while didn't go off and it was annoying me. Tried chrIS250's method out and it worked! Thanks Chris!
Old 01-05-10 | 12:04 PM
NoHoIS350's Avatar
NoHoIS350
I guess i was lucky i just installed JoeZ intake pipe all is good. No lights on. The only thing that sucked for me was re setting everything.(I unplugged the neg battery cable)Took a bit of time & reading manuals cuz i bought my IS from a pre-auction dealer & lets just say everything i know about the car is from the forum, manual & a lot of hitting buttons going Yes i got it. Hahaha
Old 01-05-10 | 02:56 PM
Kurtz's Avatar
Kurtz
I left the battery plugged in when I installed my F-sport, no good reason to disconnect it honestly.
Old 01-05-10 | 05:22 PM
NoHoIS350's Avatar
NoHoIS350
Yup your right. Next time prob just leave plugged in. Athough my car does feel better, I guess a reboot helped. hahaha
Old 01-06-10 | 12:14 AM
lobuxracer's Avatar
lobuxracer
Tech Info Resource
How does resetting the oil change reminder affect the ECM?
Old 01-06-10 | 07:45 AM
Mv350's Avatar
Mv350
thats exactly what i was thinking
