Whining Noise...Any Suggestions?
Hello Guys,
I am getting very annoyed by my car right about now. The belts or something associated with them has started to whine again. I had this fixed at a dealership about 25k miles ago, but its back again though not as bad as before. They apparently replaced the belts, but I am not very positive about that. I would take the car in again, but the last time I was there they scratched up my dash and gauge clusters while fixing a problem I had, so I don't want them touching my car again! argh. Do you guys have any suggestion as to how I can fix this noise? This noise has always lingered around with this car and its embarrasing sometimes! Haha, especially in the morning. Any suggestions would be greatly appreciated!
mike I have the same problem as you do, first off if you habe low miles them Im pretty sure that the belt starts to whine early in the morning or when the car is cold, correct? If thats the case then you really cant do anything about it, its just do to damp and wet weather. and once the belt dries off the noise will go away. The second option is that the car has high miles on it and your belt has some wear and tear ( but it cant be this since you just changed your belt ) and it could be cracking, if thats the case then you need to change your belt again
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
biggie - You are completely correct when saying it occurs in the morning on start up and in damp conditions! After running for a while, it seems to go away. Argh, why is this? I mean I do understand the logic behind it, but why don't all cars do this then? I have about 53k miles and the belts were "changed" at about 21k, so I am not sure...though I am going to check to see whether or not they are tightened properly like zenki said. I do appreciate the help! Take care guys!
To be sure that it's the belt that's causing the problem, buy a "Belt Dressing" spray from a car parts store. Run the engine on Park, open the hood and spray it on the belt while the whining is on. If you notice a change in noise, then you've hit the problem. In my experience, belt dressing sometimes can quiet belt squeaking noise.
Alright, I tried belt dressing! Solved the problem for about 5 mins! argh! The squeak is gone from idle to about 2.2k rpm, but after that...it gets very bad! At this point, I have no idea as to what to do!
Alright, I decided to just try replaced the belt once again. Well, after 2 days in rainy weather, no problems at all! I ened up going with a belt from Autozone for 14.99 as opposed to the one Lexus sells that is made by Mitsubishi for 70.00. If this solves my problem for at least 10k miles, I will be extremely happy. I think the amount that lexus charges for these items is outrageous! Listen to this one, I usually get charged 13.33 for an oil filter at lexus when my car is service and I am lazy. When I do the oil changes myself, I go to a toyota dealership and they normally sell the same exact oil filter for about 7.00. Does this make sense? Nope...oh well. Thanks for all the help again!
Here is a new one, the squeal lessens when the AC is turned on. Why is that? I hope the AC clutch is not going bad! It costs nearly 600.00!
Hope the replacement belt takes care of the noise permanently. One suggestion, check your belt every 3 months for cracks. I've tried those belts myself in other cars (not the GS) and I've found that except for the ones manufactured in Canada which held the best, some can crack within a year. The one the Toyota/Lexus sells is actually MITSUBOSHI (it's with an "O") and they're really great for the long haul.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Thanks for clearing that up
I do realize the belts may be of a cheaper qaulity than the Mitsuboshi one, but if this is the solution to my problem...I wouldn't mind replacing it every 3-6 months because the install only took less than 5 mins...
Anyway, my problem probably starts with me living in Michigan where we normally see worse weather than the general population of clublexus...Thanks again!
