640rwhp at 19psi, Th400 w/ unlocked converter
#61
Here you go. I am gonna help you out
These are pics from your engine and head. Any decent engine builder or head guy can tell you and everyone what trash it is.
From a respected engine builder:
The porting on those heads are some of the worst that I have ever seen. For christ sake there are still huge nicks in the port from the carbide even after it has been polished. None of the ports are uniform....anyone want to argue that? I have never seen a port respond well to having material taken away from the floor let alone taking at least .250" from it. He also did little to no work on the short side radius where 2u heads are in dire need of work. Also notice how the chamber has been cut out which in turn completely ruined the heads. I find it funny that someone would charge for that trash. He stated in his build thread that the heads were never flowed, but having ported and flowed these heads personally I can promise you they are worse than stock.
Only a fool would try to change a modern closed chamber hemispherical/quench head to an open chamber by freaking milling out the quench pad. It simply doesn’t have the correct geometry to support good/complete combustion. Combustion chambers like this are similar what you find in “flat head” engines. Not to mention the volume to surface ratio gets MURDERD by doing something like this.
![](http://i15.photobucket.com/albums/a355/c0wboy/Finishedheads.jpg)
![](http://i15.photobucket.com/albums/a355/c0wboy/2uzblock16.jpg)
![](http://i15.photobucket.com/albums/a355/c0wboy/2uzblock17.jpg)
![](http://i15.photobucket.com/albums/a355/c0wboy/2uzblock18.jpg)
![](http://i15.photobucket.com/albums/a355/c0wboy/polishedports2.jpg)
![](http://i15.photobucket.com/albums/a355/c0wboy/polishedports.jpg)
![](http://i15.photobucket.com/albums/a355/c0wboy/Finishedheads1.jpg)
#63
Banned
Yeahhhh, you do know this build builds some of the strongest Toyota motors around, right? So if it's such garbage, why is it making good power? And what is my compression ratio, since you have the answers. Oh, and I know what "engine builder" wrote those scathing comments. It's someone who steps on the backs of others work in an attempt to elevate himself.
Also, you know what a quench pad is, correct? And 99% of the aftermarket forged pistons do not take advantage of it? Again Alpha, you're copying an pasting.
#64
Banned
Eric
#65
Thanks the lord someone with sense can chime in here. And i call B.S. those were not "in process pictures." Please stop playing the i am the victim and everybody is out to get me role. We all supported you and were giddy excited about this project for three years. Do you know how many people build engines, blow them and re-start? Many. My first 3.4L blew a hole in piston #6 on dyno run number four because i had a douche bag tuning it that had no business tuning such a modified car. But i didnt try to hide the faults of the engine. I picked up my stomach off the floor spend the money and rebuilt the engine and this time i had Justin Nenni tune it the right way.
None of us would have been upset if you came out and said "guys i messed up, or my engine builder messed up, the engine is too high of a compression we need to fix it." Who cares no big deal. But when you try to pretend that because you have so much money and dont mind running Q16 or that it takes so much more effort to tune on pump gas which is complete garbage is what upsets me and everybody else that followed about this project.
#66
Banned
Again, I don't have a high compression ratio. I don't know how to make it any more plain thant that. What do you think my compression ratio is?? I keep hearing about this, but I haven't gotten an answer.
#67
I dodn't sayI have so much money that I run Q16, I said that I run Q16 because I don't drive my car but once or twice a month. I don't run it every day or even every week.
Then please shut me up by running your car on pump gas and do a few 14-16psi dyno pulls all documeneted. Then i will bow down and apologize in front of the masses
#70
High enough that your car cant see 16psi on pump gas and hold it together
#72
Haha awesome. You have to show an either empty tank going to 1/2 or 1/4 tank going to full. That's only appropriate since what were trying to see is your car here run on 93. I, personally, think this is fair. You don't need to strap onto the dyno ($$$) and we get to see what we want.
#73
Banned
Let me let you off the hook here, Alpha. My compression is 175 psi across the banks. According to the TIS, and maths, that equates to 9.6:1CR. Now that's dynamic. The intake valves close 37degrees ABDC, so again by the maths, the static ratio is 9.77:1... exactly the spec called out. -16cc dish on the pistons. See... I know what my CR is, and you're welcomed.
#74
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Impressive and interesting build Eric, but this isn't a 2nd Gen Lexus GS.
You have also been warned several times on past threads that we do not allow (nor do we need) the back-and-forth drama on CL which you've participated in here again.
This thread is closed; please do not repost it.
![Closed](https://www.clublexus.com/forums/images/smilies/mfr_closed1.gif)
Nonsteezy
Florida Lexus Club
16
07-30-06 07:57 PM
