Any way to disable auto shift in manual mode?
IDK I was hoping for something in the software department :/ . Valve body is a great idea though! I'm going to look into that.
^ Before you edited your post.... Now: I KNOW you cant shift whenever you want in manual, but mine is shifting at 6500 rpm!!!!!! I WANT IT TO GO TO 6800 and do the firm shift that it does if you shift at around 4000 before it decides to shift for you. BTW this fiasco has ensured that my next car will be a manual even if all I ever do is sit in traffic.
it wasnt a hostile response, I'm just giving you facts to answer your question. If you don't want an AUTOMATIC trans to shift for you...manual swap it. As far as software, there is none. Get a valvebody upgrade from Mark at Clubna-t.com for a little more than a hundred bucks and your shifts will firm up.
Sorry it's not the answer you wanted to hear, but it's the answer you asked for.
No need for a V160/161 or even an R154. With the power your stock or even moded GS won't be enough power to have to drop that kind of money for a V160. A w58 is cheap and reliable under 450hp, so you can even be NA-T and be fine with the W58.
