Best source for 3.76 LSD
I believe that Carson Toyota/Lexus (L-tunedparts.com) sells them new for $1699. I got mine new from a CL member on here about 2 years ago for $1200/shipped and came with new rear axles. Look around and you may find a better deal. The unit you WANT is from a 93-95 Supra TT (automatic). This is the Torsen style 3.76 LSD that works best for the GS4XX. GL!
At certain performance intervals it may be slower due to the unit changing the shift speed points as compared to the stock 3.23 gearing.
IMHO the only and MAIN reason to get this is if you need more traction. Well, or if you do track courses...which I do NOT do.
I would rate this as an 8 only if more traction is needed. If it is needed and this is installed you will be happy on the straights...and the LSD also works great when powering around corners and tight curves.
Fair enough -- thanks! I definitely think the LSD would be nice, but wasn't sure if the new gear ratio is worth the gas mileage drop...I've read it makes you a little slower to 60 because of one more gear change.
I think I'm going to look for just the LSD part. The low-end would be nice, but I'll get that from the torque converter.
In race from 0-63mph the 3.76 LSD car will be faster because then the 3.23 car will have to shift to 3rd whereas the 3.76 will already be into 3rd
Now, if BOTH cars are modded for power with intake/headers/exhaust/AF controller and a PI TC is added to car B then car B with the 3.76 gearing WILL be quicker than car A in this instance as well because more power will be put to the ground (traction) more effectively.
The addition of the LSD portion to the stock 3.23 gearing is GREAT only if you have a lot more power going into the car IMHO. A lot of FI guys like to keep the lower 3.23 gearing due to the fact that with all that power they don't want all of it off the line (more would be multiplied with the 3.76 gearing) as traction would then become a huge issue. Another added benefit of the stock 3.23 is that the top speed of 145+mph can still be attained.
For example. Let's say you had a 700whp supercharged vehicle with rather instant torque many would want 2.8X gearing to help with initial launching; it would help to sort of "buffer" all that power. On the flipside, if something such as 3.7X or 4.11 gearing was used in that application it would be near impossible for the car to hook up...EVER, especially off the line.
So for less powerful vehicles I think steeper (such as 3.76) gearing works better for all around drivability and performance. As more power is added one could/should go down in gearing. Think about this...a BONE STOCK IS350 utilizes 4.08 gearing and can achieve a 4.8 second 0-60mph time with just 306hp (crank)/250ish whp. This is what good gearing can do. The thing is, this gearing works so well for THIS particular car because it also has a 6 speed auto tranny whereas the older 2nd gen GS's only have a 5 speed auto tranny. The more speeds that a transmission can have the steeper the gearing can be without extreme MPG loss or top end loss. The IS-F is another GREAT example with an 8 speed auto tranny and pretty steep gearing for acceleration. the 7th and 8th speeds are strictly for fuel economy. That damn car can probably cruise at 2000rpms at 80mph in 8th gear while my car is at 3000rpms at 80mph in 5th gear; eating A LOT more gas. Just goes to show that technology is amazing...you can have the best of both worlds without any sacrifice...except for in the wallet. lol
OK, another question for you Rock (or any other LSD gurus out there reading this)...
The Surpa (3.76) rear end is rare and expensive to say the least. But I want LSD and higher gearing... Well, the 2GS3's diff bolts up to the 400, doesn't it? And it runs a 3.92 I believe (a whopping 0.16 difference from the Supra)... Isn't there an LSD kit for the GS300's pumpkin? Wouldn't that be easier/cheaper to find?
Frank,
Alexus 300 hit the nail on the head! There are a couple of LSD units sold out there...the three most common are:
1. the RMM 3.76 LSD (or otherwise known as the Supra TT LSD; they are BOTH exactly the same); complete pumpkin, direct bolt-on and ready to go ~ $1600 new
2. the TRD LSD; a drop in type LSD where you install it inside your existing pumpkin (differential) ~800 new but MUCH more labor is involved with this install
3. the Kaaz LSD; VERY similar to the TRD LSD as it too is a drop in type LSD ~$1000 new
Yes, you can buy an oem 3.92 open diff (from a GS300) and buy either the TRD LSD or Kaaz LSD; they both just drop right into that 3.92 pumpkin from what I understand; but verify when ordering of course. You RARELY see these drop-in type of LSD's used for sale on CL. So expect to pay the $800 no problem. For the 3.92 diff you could either source one from a junk yard and pick it up for perhaps ~250 or so. Or, you can try to find a person with a turbo'd GS300! %2
