My build has began!!!
#46
JeffTsai no your right i did forget to mention that you would have no traction control. but when you are putting that much money and power under the hood i doubt you would still want it. i see what you do when you do your builds you try to keep everything working and not try to loose anything. the thing is when you remove the throttle you have to take the loop compeletely out. that way the computer wont try and read that signal. just like when you disconnect the vvti sensors, car still runs. by the way that is ghetto on hiding the other throttle lol. by the way which stock computer are you using. the stock one from your car or the one that came with the motor swap?
#48
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
EDIT: Any update NJS?
#50
#53
Thank guys!!!! We are going to start the swap next week for sure.. I can't wait!!! Waiting on a few last items to come in then it's a go.. I will have dyno numbers hopefully in 2 to 3 weeks...
