anyone use polyurethane hangers?
my tanabe tips are off alittle bit and rather than using hose clamps or zip ties, i was thinking about using these.
http://shop.group5motorsport.com/cus...s/g-51789.aspx
trying to get some demensions on the stock rubber hangers and then going to buy some shorter polyurethane hangers.
thoughts?
thoughts?
its just hangars, go for it. can't see the price tag, dunno the company but i'd probably check up on them every few months to make sure they arn't starting to crack and deteriorate
cobb tuning also makes them but they are for subi's. i saw these and the cobb's priced at $11 each. the cobb ones are 15mm. i'm trying to get some info on the stock rubber hangers but i'm not having much luck. anyone help with this?
after putting my megan mid and tanabe on the tips are way off. the left sits lower than the right but both aren't hight enough for my taste. i would like a one finger gap now they are about two. also both tips aren't centered in the cutout they both are alittle to the left. so a couple shops i have talked to said to get these poly's cause they are way more rigid than the rubber and have better adjustability as far as more holes ie: left to right and up and down. i just don't have any experience with these.
maybe i'll just buy them and try them. hell if they don't work the way i want then i'll just go back to the old trusty zip tie!!!
