Diff options for GS400
I'm assuming this is the differential everyone is picking up when they switch to 3.76 is:
92-96 MKIV Supra
w/turbo, MT (3.133 ratio) Limited Slip
97-98 MKIV Supra
w/turbo, AT (3.769 ratio) Limited Slip
So is it safe to assume this will fit in our car as well:
92-96 MKIV Supra
97-98 MKIV Supra
I know changing from 3.26 to 3.113 isn't the direction most people want to take. But my though is this might be a cheaper differential to purchase. I'd almost be willing to bet most people wouldn't notice the difference in performance and you'd be gaining the LSD to boot.
92-96 MKIV Supra
97-98 MKIV Supra
92-96 MKIV Supra
97-98 MKIV Supra
everyone gets the auto diff because it fits in the gs400 housing. from my limited research on the supra diff, the MT diff is larger and wont fit in the gs400 housing.
found a lead on a guy that has a couple parts SC300/400's in my area (what are the odds lol) sounds like he has an auto diff and a manual diff....going to do some searching and see if there is a difference between the 2.
i have searched BRO (man i hate that word) like i said before, info is scattered all over the damn place. there is hardly ANYTHING that is black or white on this subject. some threads, people will say, such and such diff fits with no modifications....then 3 posts later someone says it doesnt "bolt on" and then a couple posts later someone goes on about the differences from year to year. i would really be p.o'd if i spent a few hundred bucks on a pumpkin only to find out it didnt fit and i got some bunk info. i do search, i search A LOT...and the answer is very muddy so i figured i would make a thread. these parts are not very easy to find for me locally (there is not a single lexus sc300/400 gs300/400 in any of the 9 junkyards that are within 50 miles of me.) so i want to be clear on what i need....
anyways, YES the gs300/sc300 pumpkin is what i have my eye on....and NO im not scared to do the 4.27 and daily drive it (based on slowdrivers personal experience, and facts about his car, its hardly any more strain at freeway speeds...besides, im rolling on some big *** 20's) i come from the honda world and turning 5k on the freeway and daily driving on a 4.9fd is something i did for years. i have my reasons for doing this, and doing top speed, 130mph runs is not one of them lolol...besides, the cool thing about gears is......if you find you dont like it....replace it!
i appreciate the usefull info
Sounds good DumpedGS!
I say go for it, but are you going to go with a clutch-type LSD? If so, is your car modded more than 133% over stock output (or 400hp-crank)? When I read the disadvantages of the clutch-type LSD I feel that since it REDUCES gas mileage then it is adding to further powertrain loss (i.e. more friction); probably why it is stated that it should be used on a HEAVILY MODDED car. IMHO, I would NOT go with this type of LSD if you aren't going extreme as far as power mods go...it could be overkill for your application and you are PAYING for lower gas mileage (more power drag) for indestructability; which at power levels under 400hp this "protection" is not necessary. The Torsen unit is JUST FINE for a nice moderately modded car - after all it is OEM to the Supra TT.
BTW, FYI...there is probably minimal difference in performance between the 3.76/3.92 gears (with lightweight 18" or 19" wheels VERSUS the 4.27 gears with heavy 20" wheels...rotational weight is a Bi Tch! Just some food for thought...
GL!
GL!
Let us know what you end up doing. I still have the GS3 rear end, and could end up getting rid of it if the price is right. It has about 160k on the clock, but that's nothing. I'd put it back together for you so you can just bolt it in.
Let me know if your interested and I'll check needs to be done to put it in your hands.
Here is all the information you need (http://mkiv.supras.org.nz/specs.htm) to find out what will fit in your car in terms of the MKIV Supra. Your rear end is identical to a MKIV Supra 4-speed auto which came with the optional LSD, but very rare. It is referred to as the axle code and our housing is a 'A-type' housing, the Manual 6SPD LSD is a 'B-type', which signifies the 10 bolt ring gear vs. the 12 bolt ring gear. Towards the bottom of the page you will see a breakdown of the differentials. Not all ratios and options went from 93 to 98, so when I say that I am just saying that it is somewhere in those years. You can't use a 6-speed MKIV TT LSD (12 bolt) 'B-type' because it doesn't fit inside the 'A-type' housing. If you choose to buy the pumpkin, I believe you need to buy the housing, and axle shafts as the differential is a different shape as well. Why would you further gear the GS down from 3.26-3.13, you might not even need LSD as that point. You also can't use a MKIII/IS300 LSD because it is a differential style, and size. Here is what will work if it is pulled from a MKIV Supra/Aristo, not to say one couldn't be pulled from a JDM Crown, idk... I know that no Lexus came with an LSD.
93-98 MKIV Supra (JZA80)
w/turbo, 4-speed AT (3.76 ratio) LSD
w/o turbo, 5-speed MT (4.08 ratio) LSD
w/o turbo, 5-speed MT (4.27 ratio) LSD
w/o turbo, 4-speed AT (3.76 ratio) LSD
93-96 Toyota Aristo (JZS147)
w/ turbo, 4-speed AT (3.76 ratio) LSD
If you want to keep the 3.26 gearing, and just buy an LSD insert, look to spend a good $800-$1500 depending on the brand, most people get the TRD insert, but the cheapest I've found was $850, and it didn't include shipping. Since we have to order it at my dealer, they won't give me a price break, so I laughed at the parts guys when they told me $1000.... Anyways, looks for a used one or new one, either way it'll be a few pretty pennies.
As far as the articles or where to get your knowledge....
Good read, good info, not reeeeeeeally what your looking for, but it's the theory that counts.
https://www.clublexus.com/forums/per...0-pumpkin.html
He has a list of 4 threads, as well as some other useful information in there
http://www.supraforums.com/forum/sho...d.php?t=567267
And this is the main article where I got most of my info from, then it expanded from there...
http://www.supraforums.com/forum/sho...d.php?t=484348
Let know if your need any more help...
thank you guys for posting all this info...it makes it that much easier for the next guy that is searching for the same answers
and yes i will be dragging and drifting this beast. i am infatuated with building 4dr family type cars that go fast, corner hard, and are just a kick in the *** to drive/play with. i adore the creature comforts inside this car, and the capable power plant. this is just a small step in the overall scheme of things. drivetrain and suspension are first...then more power (already started collecting turbo parts) there is a method to my madness haha....ive driven a couple rwd's with welded diff's and its not as bad as everyone makes it out to be...the 240sx i drove only chirped the tires at like sub 5mph speeds. something i can live with in order to leave 2 solid black stripes at will
again, much appreciated!!
(PS...i posted up a shot in the dark thread on my local forum, and got a PM this morning from a guy that has a gs300 pumpkin from a car he parted out that had 80k on it....going to grab it this weekend for $80!)
for reference, i have successfully swapped a few A series diffs. I have a six speed trans so i was looking to match my gear close to a supra without having to pay supra dollars.
My car a 99 GS300 . stock 390 gear...... i got a diff from a GS4xx that had a 3.27 gear in it. I be-leave the housings were the same but the companion flanges were the only differences between the gs3/gs4 . I then found a used LSD unit from a supra just the Differential , assembled all into my housing 3.27 ring and pinion and supra auto tt LSD unit. works excellent.
Hope this helps
Hope this helps
Hope this helps
Hope this helps
Hope this helps
Hope this helps
Do you have more power to take advantage of that gearing?
For those that owns the supra or have LSD w/power ... is 133% the max it really can handle? So does that mean the supra guys with more power are not running thier LSD and opt for another solution?
I can't for sure say the power limit, but I am sure there is one. I know that the guys who are really making a lot of power are opting for the TRD LSD or carbonetics, tomei, kaaz, etc. However, for us GS owners, nothing we have would put down the same stock power as the GTE, I mean, close, but not the same. I know that there are a few people out there running 400+hp on them, however that is about 133% of 320hp, so....again most bust them up and go for the TRD, which seems to be significantly stronger. Just from what I've read, seen, and experienced.
Read his signature, it says he's GTE'd with a V160, so that would be a Yes.
Ahh, I should be future proof then I wonder what JeffTsai is running. I might go above 400hp and still be ok... also, it's good info -- I don't have to baby the car as much knowing that (assuming no one ever got into problems with it except for Sakataj).
