Just installed Fujita Air Intake
as the title said i just installed the Fujita Air Intake this afternoon.
I just have a quick question for those who installed Fujita Air Intake.
sorry for the crappy cellphone pictures -
Please kindly take a look at PIC #2 in red circle. If i remove this box would that be ok or no? Because after i installed the Fujita i can't put this box back to align with the screw holes to tight back the screw. The other end of the box hitting the mushroom. So i would like to check with other Fujita Intake users they have the same issue like i do or no? In the other hand i would like to know what is the pros and cons by removing that box.
Thanks all!!
Thanks all!!
i believe it'll fit, but when when i had the fujita SRI i left the underhood air funnel/scoop out.
however, the issue you may run into is that without the bottom portion of the oem airbox holding up the end that goes into the oem airbox, it'll only be held in place by a bolt on the intake end - which means the rest of it is dangling in your engine compartment.
it's just something that i'd rather not worry about. YMMV.
with those open element intakes, you need ALL the air you can get. Leave the scoop!
Unless you're going for mpg in which case you'll remove the scoop and suck in engine air.
