Engine Light on and Diagnosis
You should really find out what code your car is throwing.
That way we can give you more specific help.
Other than guessing, there is no other way...
OK, so in another post GS400 "cats"
maybe this picture will help
Alright, thanks for everything guys. Sorry I am a bit of a noob I was just confused when
BichoteGS said
BichoteGS said
most likely the code will be for 02 sensor heater circuit malfunction. that means the sensor is still good but the internal heater is bad. that will cause you to waist a lil more gas when the engine is cold but will run fine after the engine hits operating temp. i have codes for the heater circuit on all 4 of my sensors i fixed the light by removing the dash and unplugging the light for check engine lol. if it is a heater circuit code it is not to severe and will not damage anything
