View Poll Results: Does your transmission behave like mine?
yes
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
28
66.67%
no
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
14
33.33%
Voters: 42. You may not vote on this poll
Lets talk about transmission behavior when the car is cold
When the outside temperature is around 80 degrees or less and my car has been sitting for a long time, lets say 4 hours or more, something annoying happens.
When I start driving the car, it will shift into and out of park/reverse/drive just fine. However, once I start going forward the car will hold first gear until around 2600 rpm's and then shift rather hard into second gear. After this happens once, it will not happen again for the entire trip.
I can litterally drive down the street when this is happening and not let the tach get over 2500 rpm and the car will not shift out of gear. The second I let it cross 2600, bam..gear change.
I cannot believe this is a mechanical issue with the trans. Its almost like the ecu is sending it a signal to hold first gear for some reason?!
I have no check engine lights, the transmission fluid is fine (changed about 10k ago). 151k miles.
The car has been doing this consistently for the last 5k miles and intermittantly before that for whole time I have owned it (around 11.5k miles).
Does anyone else have this problem, and if so has anyone found a sucessful fix or explanation of the problem?
what kind of mods do you have done to your car? I get a similar shift from 1st to 2nd and 3rd depending on how hard I'm driving. Nothing bad or troublesome though. Kinda just the way i drive plus i have an intake and non-restrictive exhaust setup.
I'm concerned because the car only used to do it when the temp was 45 degrees out or lower. Now it does it all the time, except one day we had over 80 last week. The frequency of the "problem" has increased, suggesting to me that it is not normal.
not a prob with me, but like TL said, let it sit and warm up, what year is yours? mine is a 99 with over 200k on the spedometer, the only thing that does bug me is when i throw it on D it gives me a small thump grom the rear
check your batt, and start to let your car warm up see what that does
1999 GS400, 151k
Not to TJ, but my car had transmission engagement problems whenever the battery got old. Caused the trannies to be replaced two times under warranty, and I almost replaced it a third time, before I fortunately found the root cause (battery).
