Have someone got the same problem like me?
HI, I have the 2009 is350, I changed the HKS exhaust and Invidia mid pip last week~ However, I can not start my engine today.~~ I use the engine check machine ~ is show the P0102 code ~ Is mean Mass Air Flow (MAF) Circuit Low Input. Also the engine check light is show out. ~
Right now I just have the fujita intake , HKS exhaust and invidia mid pip.
If someone got the same problems like me~ please help me >< thanks
or someone know what 's going on please I need your help >< thanks
HEY! quit asking the same question over and over. Pay attention to what these folks are trying to tell you. The maf sensor is either dirty, hooked up incorrectly or you have a bad sensor.
check it or replace it...and all will be well.
About the Warranty ^"^
HI , I have already changed the HKS exhaust , invidia mid pip and fujita intake in my lexus 09 is350 ~~ Is still have warranty ? and what kind of steff change will cancel the warranty ? ^^
Forum Administrator
Please stop doing that... use the button to respond again to this thread and don't create a new one each time you reply or to ask your question again. The post above is the fourth time we've merged them.
I appreciate you are new and need to learn out to use the forum software, but you're creating a lot of work and confusion. Please read some of the general forum how stuff works FAQ if you need help in using the CL forum software, thanks https://www.clublexus.com/forums/faq...b3_board_usage
Similar issue
so I have the exact issues on my 07 is350 but I have already determined I have a short in the green and black wire to the maf sensor. I'm asking for someone to give me a little tip or something on how to go about fixing the issue im jot very electrical savy but can work a multi meter and am plenty mechanically inclined. I thought maybe just run a jumper wire from the maf too the efi no.2?
To the side of the engine there is pop top cover and and slender cover with 3 bolts on it. The ECU is in there.
One of us will likely have to pull up a schematic (do some more searching MAF schematic and troubleshooting) but the wire from the MAF goes to the ECU and likely a fuse. What you need to do is find the connector and unplug it, then start tracking down where the problem is between the ECU and MAF.
I have seen a schematic on here but don't have time to find it. And seriously, start a new thread with all of your details in it. This one is a bloody disaster from 13 years ago.
Yodog (10-08-23)
