LSD to GS430-02
LSD to GS430-02
Hi.
I have read the old thread on here about the LSD/vsc.
I so bad want to find a LSD for my gs430. So what i come up with is that i have to find a Supra auto TT LSD? Can someone please clear this up for me and point me to a company or dealership that can answer my questions.
/Sebastian
/Sebastian
Keep in mind that eventhough the Supra Auto TT LSD is a direct bolt-on to our cars it does have a different ratio of gears in there. Stock open diff in the GS400/GS430 has 3.27 gears whereas the Supra TT LSD has 3.76 gears. Your car will accelerate quicker at any speed but will be mechanically limited to a top speed of around 130mph (instead of the electronically limited 147mph). You will burn a little more gas too; ~1-2mpg more.
The other route is to buy a TRD or Kaaz LSD. These LSD's must be installed in your stock 3.27 differential. They are cheaper to buy but the install is more expensive than the Supra LSD route. All in all...in the end, it works out to be close to the same - cost wise.
Good luck!
Good luck!
Good luck!
Good luck!
Thanx
